Old 06-17-2020, 04:53 PM   #1
Ptjsk
New Finish on Jimmy Top
Ok Guys,
Looking for recommendations of what to apply to the hardtop of the Jimmy.
My top had previously been sanded and painted. Some parts the sanding was still visible, and other parts still had the textured finish.
I took a sandblaster (very low pressure), and removed the paint.
Again, there are some smooth parts, but hoping these will go away with a new texture applied.
I have thought about Rhino Liner, but not sure that would hold up to the sun without fading.
I've read about lizard skin, Raptor with tint in it, and Shutz Chip Guard in a cream color (then paint).
Can anybody offer advise from personnel experience?
Also, waiting for epoxy resin so I can make the repairs on the lift gate! Looks like I need to get cloth fiberglass too.
Thanks, Pat
Ptjsk is offline   Reply With Quote
Old 06-17-2020, 07:46 PM   #2
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Re: New Finish on Jimmy Top
Deadhead NM or Iron Canine should be up for this question. I don't remember what either on used. Hopefully they'll chime in. Otherwise PM them.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 06-17-2020, 11:28 PM   #3
Ptjsk
Thanks Dale.
I did go down to the place that does Line-X and they showed me several pics of jeep tops, trailers and several other items they have done. It actually looks pretty darn good.
Pat
Old 06-18-2020, 07:45 AM   #4
DeadheadNM
Carpe manana
DeadheadNM's Avatar
My top was textured with this material here: http://67-72chevytrucks.com/vboard/s...&postcount=352
The top turned out great.
Old 06-18-2020, 08:58 AM   #5
tmontg01
tmontg01's Avatar
I used raptor spray, with white dye. After I used some flexible bright white boat paint
1968 C10 SWB 400SBC with VN327 20's
1972 K5 Blazer 383SBC
2011 Cadillac CTSV
tmontg01 is offline   Reply With Quote
Old 06-18-2020, 10:06 PM   #6
davischevy
davischevy's Avatar
For the hatch repair.
We still use fiberglass mat for reinforcement, but we don't use resin. We use a product from Lord called Fusor. In my opinion it is far superior to resin. We use it on everything from Corvettes to heavy duty truck hoods.
My son in law just did a major repair on a hatch, cutting it all apart and repairing stress points and hinges with fiberglass mat and Fusor.
He also cut the "droopy" top skin off shaped it with expanding foam, and glued the skin back on with Fusor.
https://www.lord.com/products-and-so...pair-adhesives
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 06-19-2020, 08:15 PM   #7
aotte1
Which Fusor product number do you use?
aotte1 is offline   Reply With Quote
Old 06-19-2020, 08:36 PM   #8
davischevy
davischevy's Avatar
Fusor ® 100EZ/101EZ or Fusor ® 120/T20/T21.
I like the heat set because when you get it where you want it, you can set it with heat.
I've never used the faster set ones, because I'm not fast.
The stuff is very expensive, and it mixes in a 4" mixing nozzle, so have all your work ready when you start spreading. Also get extra nozzles.
Some idiot at a show leaned on the hood on my Corvette and punched the hood brace all the way through the inner structure. I cut out a section of the inner structure, and laid fiberglass mat mixed with Fusor then laid the cutout back on and filled the imperfections. After sanding, it was stronger than new.
I put white lithium grease on the bolt threads and screwed them in the holes for the brace. The bolts made it easier to handle the cutout also.
other Larry
Old 06-19-2020, 08:39 PM   #9
IronCanine
I'm trying....
IronCanine's Avatar
We used Gravitex for the texture...and liked it very much. Then we painted that. I think any of the suggestions already presented in this thread can yield very good results. It comes down, like most things, to who is holding the gun.
Here's the specific post from our thread: http://67-72chevytrucks.com/vboard/s...&postcount=573
There's more top stuff in the thread if you're interested...link in my signature.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076
1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352
1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290
1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555
"Sometimes I wonder if zander208 was even real..."
IronCanine is offline   Reply With Quote
Old 06-19-2020, 08:46 PM   #10
davischevy
davischevy's Avatar
I wish I had known about this thread when Scot (my son in law) was working on his top. He had a heck of a time getting the texture right. I think it took three tries.
other Larry
Old 06-20-2020, 12:16 AM   #11
Ptjsk
Thanks for all the responses guys!
Looks like I'm going to try the Line-x liner. They will match my paint utilizing the same paint code I have for the body coat.
I'll post a few pics when it's completed.
Thanks again,
Pat
Old 06-20-2020, 01:24 PM   #12
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
I used this on my top when I repaired it back in 2004.
I applied it with a "schutz gun" or undercoating/bed liner gun.
The shutz gun reproduced the factory texture pretty well.
It's held up great but did yellow a bit overtime.
I ended up painting the top in 2006 with some boat deck paint because of the yellowing.
I used this stuff.
Interlux deck paint. Mediterranean White(# INTYKA184Q).
I only bought a quart because you thin it, it's more that enough.
It's thinned with the Interlux 333 thinner and simply brushed on.
As of today (14years later) it still looks great.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 06-22-2020, 08:46 AM   #13
hemi43
hemi43's Avatar
X2 on the Gator Guard. When I use this product I tint it close to the final color, but since the top is going white just spray as is with a Shutz gun. Wait till it tacks up then spray a couple of coats of single stage urethane with out sanding (wet on wet). If I was doing that Blazer top, I would cut the gloss 50% for that factory look. Been a while since I did a top like this, but Dupont (1300xxx) pre-packaged white was a perfect color. Believe it or not, white is the most difficult color to get right. Too many times I've seen tops done in a pure white, and it just doesn't look right.
Here's a couple trailer fenders I built from glass a few years ago. Wrong color, but will give you an idea of the texture.
hemi43 is offline   Reply With Quote
Old 06-22-2020, 11:40 PM   #14
Ptjsk
Thanks Bud!
Old 06-23-2020, 08:48 AM   #15
Ptjsk
WTH Larry??? A guy leaning on your Corvette to the point of punching your hood brace through the inner structure? I can't believe how some individuals simply lack any type of common sense! Glad your repairs turned out good.
By the way, what year is your Corvette?
Pat
Thread Tools
Display Modes
