06-27-2020, 01:15 PM | #1 |
Suburban rear frame notch
Has anyone done a notch on their Suburban? Not looking for anything that will require cutting the floor, just need to keep the axle from hitting the frame so frequently. I assume I will have to make one, which isn't hard, but wanting to see if anyone has done it for inspiration.
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
06-28-2020, 07:29 PM | #2 |
Re: Suburban rear frame notch
I would think a truck notch would work, frame is real similar around the axle area.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
06-28-2020, 08:56 PM | #3 |
It's actually not, it dips down sooner towards the rear and also has a body mount to contend with.
07-03-2020, 09:45 AM | #4 |
Junior Member
Why couldnt you build your own? Use some pipe or square tube.... the pipe would weld in, give you a 3"? half moon opening above axle... or sq tubing that you can box in.... its basically just a baby notch 3" would do wonders to stop the bottoming out... add some neoprene bump stops as well ...
Just a thought... and yeah Burb and Blazer rear frames are diff than trucks |
