Old 03-19-2019, 08:46 PM   #251
Clyde65
Clyde65's Avatar
Re: Best "Rake/Stance" for a Hot Rodded 60-66 C10?
Front:2.5” spindles, 1.5” ECE drop springs
Rear: airbags 40 psi
Fr/rr shock relocators
Front sway bar, lowered mount
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 03-19-2019, 09:16 PM   #252
LVPhotos
LVPhotos's Avatar
1962,
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 01-01-2020, 10:28 PM   #253
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Old school rake
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 01-01-2020, 10:58 PM   #254
Hollow65
Hollow65's Avatar
Originally Posted by LostMy65 View Post
Old school rake
Dig it
At my worst I'm at my best
Hollow65 is offline   Reply With Quote
Old 01-02-2020, 01:31 PM   #255
theastronaut
theastronaut's Avatar
1.5 coil cut from stock front springs. Bump stop brackets completely removed. CPP disc/drop spindle kit, unknown used drop rear springs, drop blocks, small pipe notch, stock front wheels with 1.5" bolt on spacers, 8" vintage aftermarket chrome reverse wheels (slightly less backspacing than 8" blazer wheels), 215/75 and 235/75 tires. The front wheel spacers really help fill out the fenderwell while keeping the skinny front wheel/tire look.
theastronaut is offline   Reply With Quote
Old 01-02-2020, 02:06 PM   #256
rcnutt
rcnutt's Avatar
Here's my 64 .....5.5" front and 8" rear. Perfect stance in my eyes.
64 short fleet
rcnutt is offline   Reply With Quote
Old 01-02-2020, 02:12 PM   #257
joe dirt
joe dirt's Avatar
old school rake
1961 c10 longbed - gone
1964 c10 swb
joe dirt is offline   Reply With Quote
Old 01-02-2020, 02:23 PM   #258
vin63
It's Better With Nitro
vin63's Avatar
Not the best, but here's how my '63 ended up. I kept it pretty close to my old Super Gas/Street Chevy II.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 01-02-2020, 02:53 PM   #259
likaroc13
Rollin' Old Skool
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 01-02-2020, 03:22 PM   #260
forestb
forestb's Avatar
I'm not sure why people are still posting on this thread. I posted my truck a long time ago.
forestb is offline   Reply With Quote
Old 01-02-2020, 03:38 PM   #261
LostMy65
LostMy65's Avatar
I know!!!!
My problem is I'm still stuck in the late 70's early 80's when the hot rods were jacked up in the back.
Old 01-03-2020, 01:33 AM   #262
C/10 King
C/10 King's Avatar
My dropped patina-ed GMC BBW SWB ……… The Hag
C/10 Rene
1966 Short Fleet "The Hag"
1967 CST Short Fleet "Dark Poly"
1971 Short Fleet
1970 Jimmy Custom 2 WD "Golden Ticket"
1972 Blazer 2 WD "Retro Blaze"
C/10 King is offline   Reply With Quote
Old 01-05-2020, 12:38 PM   #263
rustbucket66
This is a great thread. A lot of beauty trucks in here.
rustbucket66 is offline   Reply With Quote
Old 01-05-2020, 07:56 PM   #264
J Williams
J Williams's Avatar
Originally Posted by joe dirt View Post
old school rake
What is the drop on this. Looks good man and I am about to drop mine.
J Williams is offline   Reply With Quote
Old 01-06-2020, 11:10 AM   #265
rustbucket66
Thanks. 2 1/2 inch drop spindles and 2 inch drop springs in the front, and 4 inch drop springs in the rear. About as low as you can go without hitting anything or bagging it.
Old 01-06-2020, 12:47 PM   #266
forestb
forestb's Avatar
You do have a vary nice stance but I think he was talking to "Joe dirt". At least that is who he quoted.
Old 01-06-2020, 01:04 PM   #267
joe dirt
joe dirt's Avatar
unsure, it was done by previous owner...front coils are cut, rear leaf springs has some leafs taken out of the pack...it looks to be close to a 4/6 drop
1964 c10 swb
Old 01-21-2021, 10:20 PM   #268
LostMy65
LostMy65's Avatar
Originally Posted by racecougar View Post
2-1/2" drop spindles and 1-1/2" drop blocks with 29"/31" tires.
Another of racecougar.
Old 01-21-2021, 10:42 PM   #269
racecougar
racecougar's Avatar
I took that photo on Black Friday last year. Figured it was fitting to drive that vehicle that day.
I've got it all blown apart currently. Finally painting the front clip and installing a Vintage Air setup.
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
Old 01-22-2021, 10:02 AM   #270
nsb29
nsb29's Avatar
I know!!!!
That actually goes back to the 60s I also remember when it was just the opposite dropped in the back jacked up in the front
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
nsb29 is offline   Reply With Quote
Old 01-23-2021, 11:53 AM   #271
Ghetto Fireman
Junior Member
Ghetto Fireman's Avatar
2 1/2 drop spindles 1” drop coils in front 3” drop coils in rear.
Ghetto Fireman is offline   Reply With Quote
Old 03-29-2021, 11:51 AM   #272
LostMy65
LostMy65's Avatar
Originally Posted by Hollow65 View Post
Dig it
I like it especially because it makes a long bed look mean.
Old 03-30-2021, 12:18 AM   #273
goatless
goatless's Avatar
Before on the left: CPP 2.5" modular drop spindles, 4" lowering springs, 454 w/iron heads. Lots of lower control arm scraping on semi-bumpy roads.
After on the right: CPP 2.5" modular drop spindles, 3" lowering springs, 454 w/iron heads. No more scrapes.
Rears combo lowering springs and blocks.
1964 C10 LWB->SWB, 283->454, SM420->200-4R
MECHANIC: "ME"
goatless is offline   Reply With Quote
Old 03-31-2021, 12:32 PM   #274
pdxhall
pdxhall's Avatar
Here's mine. 2 1/2" drop spindles & 1" drop springs in front. 5" drop springs in the rear. no bed yet or full tank of gas so it will probably come down another inch or so in the rear.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 05-09-2021, 03:52 PM   #275
LostMy65
LostMy65's Avatar
Saw this coming back from Longview yesterday.
