Old 08-29-2020, 07:49 PM   #1426
OregonNed
OregonNed's Avatar
Re: What did you do to your truck today.The 3rd chapter
close up
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 08-30-2020, 12:26 PM   #1427
KMC3420
KMC3420's Avatar
Finished making my patch panels for where the firewall and floor meet. Need to weld these in before pulling the old floor out.
Drivers side
Passenger side
Keagan
68 SWB C-10 original 350 A/C 503 Mean Green
KMC3420 is offline   Reply With Quote
Old 08-30-2020, 06:31 PM   #1428
72c20customcamper
72c20customcamper's Avatar
My wife says I have a problem .
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 08-30-2020, 07:22 PM   #1429
KMC3420
KMC3420's Avatar
A problem maybe, but I see you found a solution as well!
Keagan
Old 08-30-2020, 07:30 PM   #1430
FRCvette
I installed my new chrome bumper from Cooper Restorations today.
There's something women like about a pick-up man
1967 c10 swb Stepside
2004 SSR
2013 Silverado swb
FRCvette is offline   Reply With Quote
Old 08-31-2020, 08:37 AM   #1431
67C10Step
67C10Step's Avatar
72C20 - Yeah, but as my wife says: At least I don't have to go from bar to bar looking for you. I know right where you are when you disappear.
KMC3420 - I would like to know more about the patch panels. I need to do this exact same repair only my truck and was looking at it over the weekend trying to come up with a plan.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2020 Toyota CH-R
2020 Acura MDX
67C10Step is offline   Reply With Quote
Old 08-31-2020, 10:44 AM   #1432
Davidf
Removed about 3/8" of body filler on the corner of my hood only to find poorly repaired previous damage. The bondo sculptor was not very good as the corner was way different than the other side. So, I opened her up to get some of the metal back to normal. Notice the single vertical cut and how far it opened up to get the metal close to where it belongs. Any suggestions on making a (compound curve) patch panel? A patch panel would sure come in handy if any has one available.
Davidf is offline   Reply With Quote
Old 08-31-2020, 12:24 PM   #1433
BugzC10
BugzC10's Avatar
Finally got a spare and had the garage floor coated for her
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline   Reply With Quote
Old 08-31-2020, 03:00 PM   #1434
KQQL IT
At the body shop.
KQQL IT's Avatar
New key and tumbler for old blue.
The other key could come out and be turned off with anything and occasionally didn't need a key at all.
Old 08-31-2020, 05:51 PM   #1435
72c20customcamper
Did the drip rail today SEM self leveling seam sealer tried to get the truck as level as possible but it still puddled up in the front . Roof is now in high build primer plan is to paint the white this week
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 08-31-2020, 10:03 PM   #1436
KMC3420
KMC3420's Avatar
I started out by cutting out the old to use as a template and then measured the template. From there I put my measurements on a flat piece of sheet metal. I use a bender I made for my shop press to bend up to 90 degrees. For cutting I use my right and left hand tin snips. Just take it nice and slow and sneak up on your final fitment.
Template
Template
Bender
Keagan
Old 08-31-2020, 10:16 PM   #1437
KMC3420
KMC3420's Avatar
Snips
Press
Keagan
Old 09-01-2020, 07:19 PM   #1438
Old_Gold
Old_Gold's Avatar
Nice forming attachment for your press!
Jim
Old_Gold is offline   Reply With Quote
Old 09-01-2020, 11:51 PM   #1439
3757chevy
3757chevy's Avatar
Jim
'67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 09-02-2020, 07:37 AM   #1440
67C10Step
67C10Step's Avatar
KMC3420,
Nice, thanks for that information and the photos. I think I may have everything in my shop to build one of those breaks for my press except the black iron Tee. Like I need an excuse to go to the hardware store!
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2020 Toyota CH-R
2020 Acura MDX
Old 09-02-2020, 09:28 AM   #1441
KMC3420
KMC3420's Avatar
Thanks guys, it works pretty good for simply bending sheet metal, intended job. I often see attachments for a press (online), and gotta at least try to make the online $100 part for $10 worth of scrap metal and some welding wire.
Keagan
Old 09-02-2020, 10:31 AM   #1442
Boog
laying low
Boog's Avatar
If only the repro parts vendors would try something similar.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 09-02-2020, 11:50 AM   #1443
KMC3420
KMC3420's Avatar
You got it! Wouldn't that be something, if successful they could dominate the market..
Keagan
Old 09-02-2020, 12:02 PM   #1444
A1971Blazer
A1971Blazer's Avatar
disassembled the power steering gear....
cleaned and painted the case.....
ready to re-assemble
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is online now   Reply With Quote
Old 09-02-2020, 10:35 PM   #1445
basketcase
basketcase's Avatar
I would make 3 maybe 4 small pieces which would be easier than trying to do that complicated form all in one piece. Tack them together and work with them until you are close enough to hammer and dolly and get by with just a skim coat of filler. Make cardboard templates from the good side for a guide.
Tom
'69 swb stepside in progress.
'59 Corvette lifetime project
basketcase is offline   Reply With Quote
Old 09-03-2020, 12:19 PM   #1446
ohboy321
ohboy321's Avatar
Put the first coat of black paint on the steering wheel I'm restoring. This is my first attempt at making a part as smooth as possible before paint is applied and so far it is coming out pretty good.
Steve/NH
1967 K10 327 Short Bed Stepside
2008 F350 Power Stroke
2007 BMW X3
2020 BMW 540xi
1995 Harley FLSTC
ohboy321 is offline   Reply With Quote
Old 09-03-2020, 01:51 PM   #1447
72c20customcamper
Painted the firewall this am . Going away for the weekend but I plan on painting ths roof monday . Going with 562 off white eventhough it's not original to the truck .
Should start taking pictures with my good camera . Phone sucks
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 09-03-2020, 07:28 PM   #1448
jimijam00
Drove it across the state for the long holiday weekend. 250 miles in the 90+ degree heat, 75 mph air conditioning, and had to stop for gas twice. That's leaving home with a full tank too. So two tanks, and then a little more to get me the 250 miles.
jimijam00 is offline   Reply With Quote
Old 09-03-2020, 08:47 PM   #1449
fourspeedwagon
fourspeedwagon's Avatar
It’s time to put the engine in my ‘71. I pulled the driveshaft and greased the Ujoints, painted the inner fenders, core support, hood hinges, etc.
Got the engine and trans lowered into place and bolted up. Got all the exhaust bolts wire brushed and found the half moon tangs the go on the exhaust bolts and cleaned them up too. New exhaust manifold gaskets, I spaced getting new heater hose so I need to go grab that. I’m sure I’ll find some more things missing but hoping to hook the wires all up and light the fire on Saturday.
It’ll be fun- I got the truck with no engine so I’ve not driven it yet.
1951 GMC 250 Open Express Pickup
1968 Suburban C10
1971 C20 Olive
“People are shocked when they find out I’m not a good electrician”
Dad told me “Son, never strike a man in anger- unless you’re certain you can get away with it”
fourspeedwagon is offline   Reply With Quote
Old 09-04-2020, 03:51 PM   #1450
fourspeedwagon
In the daylight it looks like it could use a shampooing- but still well worth the price paid!
Edit- oops, put this in the wrong thread. Anyway, this is a freebie seat I got last night.
1968 Suburban C10
1971 C20 Olive
