Old 06-22-2018, 11:35 AM   #1
Black Momba
Tilt steering
I’m considering ididit column. I’ve talked to several tech support but some tech support say 32” and 38’? It’s for my 1966 c10 shorty with a big window.
Black Momba is offline   Reply With Quote
Old 06-22-2018, 09:33 PM   #2
Re: Tilt steering
Greetings. I don't have an answer for you, but I think someone in the 60-66 message board would. Let's see about getting this moved over there where it will be sure to be seen by that bunch
Old 06-22-2018, 10:02 PM   #3
Re: Tilt steering
It is moved...Hope someone here can get you your answer.
Old 06-22-2018, 10:51 PM   #4
AcampoDave
AcampoDave's Avatar
Re: Tilt steering
http://67-72chevytrucks.com/vboard/s...d.php?t=764270
Why not try the PVC pipe column trick I described in post #9 of this thread so you can see what suits you. Like shoes, different people need different sizes and an ididit is a big investment into your comfort and safety. You want to get it right the first time. Edit: you also need to be clear on how idid it measures their columns. Remember they have the splined stub that extends past the tube and I think it may count in the overall dimensions
AcampoDave is offline   Reply With Quote
Old 06-22-2018, 11:41 PM   #5
vin63
It's Better With Nitro
vin63's Avatar
Re: Tilt steering
I went with Ididit's tilt, column shift retro column for the 60-66 truck and it is right at 32" end to end of the shaft. I had to position the column as close to the dash as possible. A 38-inch long column would be to long for my application (I have the factory bench seat). Be sure to measure with you sitting in your seat.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 06-23-2018, 04:00 PM   #6
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Tilt steering
Ididit makes a column for our trucks - Have you looked at their web site?
Old 06-24-2018, 02:21 PM   #7
rvrfoot
Re: Tilt steering
Ididit is a lot of money.
rvrfoot is offline   Reply With Quote
Old 06-25-2018, 12:31 AM   #8
Black Momba
Re: Tilt steering
I did talk to a tech/rep from ididit and they said like 38” which differs from other sellers and jeg’s(tech/rep) at 32”?
Old 06-26-2018, 10:56 AM   #9
The Rocknrod
Moderator
Re: Tilt steering
Wow, they told me 30" whats up with that?
Old 06-27-2018, 09:49 AM   #10
LVPhotos
LVPhotos's Avatar
Re: Tilt steering
I got one from IDIDIT, I would say the retro fit is same length as stock with tilt. The mounts are slotted. Could be difference from tilt to non tilt as well.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 06-27-2018, 03:02 PM   #11
Black Momba
Re: Tilt steering
So was it 32” or 36”?
Old 06-27-2018, 03:23 PM   #12
LVPhotos
LVPhotos's Avatar
Re: Tilt steering
I don't have length, but for a rack use Part# 1120650120
It was close if not same as 3 on tree column.
Old 06-27-2018, 03:31 PM   #13
LVPhotos
LVPhotos's Avatar
Re: Tilt steering
So I called IDIDIT and the "box" is 35" and the "Rack" is 30"
Old 06-27-2018, 03:41 PM   #14
The Rocknrod
Moderator
Re: Tilt steering
What is a "Rack"?
Old 06-27-2018, 03:49 PM   #15
LVPhotos
LVPhotos's Avatar
Re: Tilt steering
Rack would be the other type of steering Apparatus,
Old 06-29-2018, 01:33 AM   #16
stsalvage
Scrapper 1
stsalvage's Avatar
Re: Tilt steering
The problem with old tilt compared to new tilt the new style in way better.What is the one thing you grab a hold of to pull your self mostly fat people but skinny people do it too is the steering wheel.That's why I've never liked tilts they get lose it take a little while to go in the tighten up the column
stsalvage is offline   Reply With Quote
tilt column
