11-22-2021, 09:41 PM | #1 |
Air Ride Compressor and Tank placement …
Not a lot of room under a blazer , anyone on air where did you put your air tank and compressors ?
Thanks |
11-26-2021, 11:12 AM | #2 |
Addicted user
Re: Air Ride Compressor and Tank placement …
I mounted a compressor on each side of the inner frame rails as it bends up after the rear trailing arm crossmember. mounted one 3 gallon tank on each side of the outer frame rail between the rear tire splash guard and the rear bumper. works great and hidden nicely. mounted the 4 solenoid valves under bed floor on a welded plate i fabbed to the "step" up from cab floor to bed floor
1972 2wd Blazer - 95% completed 2015 Silverado 1500 4wd -z 2008 AERO 9-7X (TBSS cousin) LS2 1970 Jimmy 4wd - future project |
11-26-2021, 11:40 AM | #3 |
Just an idea for tanks?
Here is the best sample picture I could find on the web images. Do you have a Welder and access to purchase Square tubing? Not sure if the bumper idea is with the theme of your build. But Custom tanks could be made to mount underneath or make a custom tank behind the bumper. Just food for though.
