07-27-2020, 12:20 PM | #1 |
Grandpa's 66 GMC SWB
Starting a thread to show my restoration in my 2 car garage over the course of the last year. From Missouri River Bottom barn to licensed in 1 year and 1 day. There were many ups and downs as I had never before welded or done major mechanical work. I used this forum daily as well as Mr Gibson on Youtube for guidance. Mr Gibson's videos, knowledge and overall attitude were very inspiring to me. I hope you all enjoy
07-27-2020, 12:48 PM | #2 |
Re: Grandpa's 66 GMC SWB
Some pictures from picking it up from the Missouri River Bottoms
07-27-2020, 12:50 PM | #3 |
Back in the early 90's. I am on the right and my brother on the left side. Looks pretty rough in this picture already.
07-27-2020, 01:31 PM | #4 |
Looking forward to seeing the progress.
07-27-2020, 01:39 PM | #5 |
Some pictures from the inital disassembly in my garage. Lots of rust
07-27-2020, 02:15 PM | #6 |
Initial repair of drivers side. First time welding
07-27-2020, 02:18 PM | #7 |
Floor pan and rear corner repair
07-27-2020, 02:20 PM | #8 |
Repair of passenger side
07-27-2020, 02:35 PM | #9 |
More of the passenger floor.
07-27-2020, 02:43 PM | #10 |
Removal of the top of the cab and above windshield piece, the inner cab forward ceiling was also replaced. I completed the inner cab repair first to maintain the 3D dimensions, then I welded the above windshield piece in second using the old outer roof and new inner roof as a guide. This was welded in position with tack welds. After secured I removed the roof, removed all the rust, chasis saver, insulation, and then tack welded the roof on the cab. I wish I took better pictures. I should have also used panel adhesive instead of tack welds
07-27-2020, 02:45 PM | #11 |
More disassembly
07-27-2020, 02:49 PM | #12 |
Sand blasted, cab/frame/doors/all usable parts in my 2 car garage. Rented a sunbelt 300lb blaster and used it the entire weekend. I went through over 1500lbs of sand. I re-used the sand as much as I could. Needless to say the neighbors were not impressed. I got 90% of the sand out of the garage but the last 10% has been coming out ever since
07-27-2020, 02:51 PM | #13 |
I primed the chasis and cab with Chasis Saver. I ended up sanding nearly all of it off the cab in favor of a epoxy primer eventually. The fumes in the house were terrible with the chasis saver. Turned out very nice tho
07-27-2020, 03:20 PM | #14 |
Engine, transmission and rear end arrived.
Engine: SP350/357 ordered from JEGS Transmission: Tremec TKO 600 ordered as a kit from SilverSport Rear End: Ford 9 inch made by Currie Transmissions, 3.7 rear end ratio Engine and transmission mated easily with new bellhousing provided by SilverSport. Their pressure plate and clutch were easy to install. My runout specs for the transmission alignment were within spec for Tremec. I chose to use a mechanical clutch for simplicity. |
07-27-2020, 03:25 PM | #15 |
Engine and transmission mounted to frame. I used the rear engine mount holes which was stock for this year truck. Pros for this was weight distribution, shorter drive shaft, and near ideal shifter location. Cons are proximity to firewall.
I had re-used by upper and lower control arms. They were all blasted, painted, new ball joints were placed. I used heavy duty springs at original ride height. |
07-27-2020, 03:32 PM | #16 |
Rear end installed. Again I had Currie make it special. 3.7 ratio, with a detroit trutrac. Since GMC's for the most part have leaf springs the hangers were added by them. Everything fit perfectly. I purchased the leaf springs through General Spring locally here in Kansas City. They are actually for 3/4 ton trucks from 67-72. They are rated for 2725lbs. The original springs were rated at 1500lbs. Here is a link to the springs. https://www.generalspringkc.com/product_p/22-409.htm
I used shakles from a 3/4 ton truck slightly modified. I used 5/8 u bolts and u bolt pads from RuffStuff. The pads are sold for 3 inch axles for Ford Broncos. All came together very well. The fuel tank is aluminum from Brothers |
07-27-2020, 03:44 PM | #17 |
Saweet! Keep up the good work!
CURRENT & PAST CHEVY TRUCKS 60 C-10 Apache short step side 62 C-10 short step side 66 GMC Long bed fleet side 305 V-6 77 C-20 Custom Deluxe (Blue Goose) |
07-27-2020, 03:56 PM | #18 |
Looks great...following along although I think you are going to be finished soon. Glad to see you with a manual transmission too!
07-27-2020, 03:59 PM | #19 |
Brake lines run using 3/8 inch steel tubing. Master cylinder was wilwood and all brakes were Wilwood. Front calipers/rotors and spindles (stock height) were bought from Performance Online as a package. These were 2 piston calipers. Rear brakes were part of package from Currie. These were 4 piston calipers.
07-27-2020, 04:02 PM | #20 |
Wheels were cheap steel 15 x8. Tires are Michelin. I would have use the original steel rims but they would not fit over the disc brakes. Front sway bar is from CPP and the largest they make. Rear sway bar is from Hellwig and also the largest they make. The rear had to be modified slightly as I did not like the mounting hardware. Shocks are from CPP
07-27-2020, 04:03 PM | #21 |
The radiator is a 4 core radiator I purchased from Classic Parts of America. The mounts had to be enlarged to fit over this
07-27-2020, 04:04 PM | #22 |
Fuel tank, rear brakes, rear end and Hellwig sway bar. Drop hitch rated for 8k pounds
07-27-2020, 04:13 PM | #23 |
You are doing an awesome job on this truck
Former Decorated Combat Marine...Semper Fi!! Instagram jorourke322 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=734699 2019 GMC AT4 |
07-27-2020, 04:26 PM | #24 |
Body work. I used epoxy primer from SPI. I used Evercoat Rage for the filler. Lots of sanding hours with many mistakes.
07-27-2020, 05:15 PM | #25 |
Assembly. Painted at MAACO. I called around to 20-30 different body shops and everyone wanted 20-25K for the job or just refused. MAACO was fair and did a fine job. This is a daily driver and not a show truck
