10-16-2019, 12:02 AM | #1 |
Blue 67
Hard start
Hi:
When my truck is warmed up or has been driven for 10-20 minutes or more, if I park the truck and when I want to restart the truck, it has a hard time to start, it has hard time to turn the engine over. I feels like the battery is running out of juice but when the engine is cold, no issue, it cranks well and turn the engine with no problem. I have covered the starter with a head barrier jacket since I thought it might be heat sink. Also, I added a new ground from started case (bolt) to chassis since the problem continued and I thought it might be poor ground. Any other suggestion(s) would be appreciated.
1953 GMC 3/4 ton: current project 1967 C20: 5.3 voretc with T5 conversion, 4 wheel 8 lug disc brake 1972 Nova: my 4 door sport sedan! 5.3 voretc + T5 conversion. drivable project, FUN!! 1979 Camaro Z28: 5.3 vortec conversion with build TH350: drivable project, Fun to drive 1992 Camaro RS convertible (Z28 clone): 5.3 conversion with build T5: on going project 2005 Silverado 2500, 4x4 Duramax, original owner |
10-16-2019, 12:11 AM | #2 |
Re: Hard start
Pull your initial timing back 3-4 degrees.
See if that helps. |
10-16-2019, 12:20 AM | #3 |
20' Daredevil (Ret)
Re: Hard start
Yep, probably timing related (too far advanced). Another thing that can cause this is stuck advance weights in the distributor.
10-16-2019, 12:30 AM | #4 |
Blue 67
Re: Hard start
I will try that.
10-16-2019, 12:36 AM | #5 |
20' Daredevil (Ret)
Re: Hard start
I remember having stuck distributor weights years ago after an engine rebuild. Mechanic said the battery was shot. It was fine. Super easy to check and to fix, if that's your problem. Good luck!
10-16-2019, 12:55 AM | #6 |
Blue 67
Re: Hard start
How did you fix it? Never done that.
10-16-2019, 08:22 AM | #7 |
Re: Hard start
Pull of the distributor cap and rotor. Move the weights around. They should move freely and smoothly.
Could check it with a timing light also. Vac advance disconnected and capped. Check it cold and hot. Should give the same reading. Rev it up to watch it advance.
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
10-16-2019, 08:57 AM | #8 |
20' Daredevil (Ret)
Re: Hard start
Sorry for the late reply, I went to bed after my previous post. Remove the cap and turn the rotor back & forth. The weights should change position when the rotor moves. Mine were stuck in the fully advanced position and did not move. They were easy to break loose so they could move freely. Never a problem after that.
10-16-2019, 03:37 PM | #9 |
Re: Hard start
Sounds like maybe fuel percolation. Are you running an Edelbrock carb?
72 C10 lwb fleetside -stock 350/350 combo |
10-16-2019, 04:48 PM | #10 |
Re: Hard start
What size is the positive lead to the starter. To small and possibly bad connections could cause this too.
10-16-2019, 04:50 PM | #11 |
Re: Hard start
Fuel perk wouldn't cause slow cranking like a semi dead battery. Perculation cause a rich start or no start.
10-16-2019, 04:59 PM | #12 |
Post Whore
Re: Hard start
Just a note to clarify this. Once set up as stated check the timing at idle and note the number. Then rev the motor till the timing stops advancing. Hold for 5-10 seconds. Then return to idle. The timing number before reving and after needed to be the same every time. If not then one or both of the advance weights are hanging up and not returning to zero. If you do see it not return to the same number try removing the cap carefully so you don't bump the distributor. Once removed you should be able to see which weight has not returned to zero advance position.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F2 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 Last edited by HO455; 10-17-2019 at 12:11 AM. Reason: Bad information was posted by me. |
10-16-2019, 05:51 PM | #13 |
Re: Hard start
10-16-2019, 08:46 PM | #14 |
Re: Hard start
Not always. I brought it up because I had the same symptoms with my truck until I put a heat insulating gasket under the carb. After that, never a hard start until the battery died 2 years later. Edelbrocks are notorious for fuel percolation.
72 C10 lwb fleetside -stock 350/350 combo Last edited by 68 P.O.S.; 10-17-2019 at 12:20 AM. |
10-16-2019, 08:50 PM | #15 |
Re: Hard start
Indeed. GM has the weights right under the cap. Pretty easy to check the weights travel, lube 'em, and set your timing to 36 total.
10-17-2019, 12:01 AM | #16 |
Post Whore
Re: Hard start
Dhoo! Sorry folks I will edit the post.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F2 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 Last edited by HO455; 10-17-2019 at 12:11 AM. |
10-17-2019, 12:41 AM | #17 |
Re: Hard start
Can you post pictures of what the terminals look like connected at the battery? And connection of the negative battery cable on the engine? I am hoping it goes to the engine. What is the condition of the positive terminal that is connected to the starter? Do you have headers or exhaust manifolds?
