08-12-2019, 05:44 PM | #1 |
compression ratio MY ENGINE PIC,S.
anybody here real good at figuring out compression ratio on a 350 sbc........ I think I,am real close to race gas on my engine build............
thanks
I BELIEVE IN JOHN 3:16 Last edited by BCOWANWHEELS; 08-30-2019 at 08:09 PM. |
08-12-2019, 07:46 PM | #2 |
Re: compression ratio
First you need to figure out combustion chamber size, piston dish/dome, gasket thickness, overbore and anything I'm forgetting. No one can tell you the CR with no info.
08-12-2019, 08:29 PM | #3 |
.030 over bore, .125 dome pistons, .015 or .041 head gasket, I HAVE BOTH , 76 cc head, 0 decked............. I,AM TRYING TO GET HONEST 10-1 COMPRESSION
I BELIEVE IN JOHN 3:16 |
08-13-2019, 01:11 AM | #4 |
Knowbody
08-13-2019, 08:39 AM | #5 |
Oh no!
My calcs come out to 6.2 to 1. I used this calculator. Punch your info in and see what you get. http://www.wallaceracing.com/cr_test2.php |
08-13-2019, 08:51 AM | #6 |
http://www.csgnetwork.com/compcalc.html
will this do it? I thought some engine guy might just KNOW from memory.
Dad always said, "Son, WISH IN ONE HAND, and ......." -------------------------------------- -------------------------------------- Current toy trucks: '71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C '72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these: '66 Plymouth Belvedere City of Miami cop car clone. '70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!! '67 C10 short/step side mount spare -- SOLD!! '72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!! '69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!! |
08-13-2019, 10:17 AM | #7 |
need cc piston dome. .125 does'nt work unless it is 12.5 cc
08-13-2019, 12:55 PM | #8 |
I,ll get cc,s on pistons
08-13-2019, 08:49 PM | #9 |
piston info-
compression distance 1.56 head volume -3.5 cc,s
08-13-2019, 09:09 PM | #10 |
Is the CC number you list an average from measurements from the assembled heads or from a chart? I've found that some Chevy heads are not very close to the advertised CC's.
Are you shooting for 10:1 so you can run pump regular?
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
08-13-2019, 11:07 PM | #11 |
10-1 is a 93 oct eng....................76CCS ARE FROM HEADS CC,D
08-21-2019, 03:46 PM | #12 |
OK, THOUGHT THERE WAS SOME REAL MECHANICS HERE BUT GUESS I WAS WRONG.
THOUGHT THIS MIGHT HELP SOMEONE.................. Bore: (diameter) in. - 4.030 Stroke: in. - 3.48 Cylinder Head Volume: cc in. - 76CC Effective Dome Volume: -3.5 (.125 DOME) Use (-) for Dome . cc in. Deck Clearance: in. -0 Compressed Gasket Thickness: in. -.039 Number of Cylinders: 8 - V8 Compression Ratio : 10.01 : 1 Total Displacement (in.3) : 355.12 Total Displacement cc's : 5821.64
I BELIEVE IN JOHN 3:16 Last edited by BCOWANWHEELS; 08-21-2019 at 03:54 PM. |
08-21-2019, 07:03 PM | #13 |
I still get 9.2 to 1 like I did at the beginning.
What do you get and which calculator did you use? |
08-21-2019, 09:49 PM | #14 |
Off of summits web site
08-21-2019, 10:01 PM | #15 |
All about them K’s
And here I thought you knew something no one else did.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
08-21-2019, 11:52 PM | #16 |
I used several web sites to calculate. All came to 10.1 to 1....
Perfect. I,am going to cc my intake and exh ports along with combustion chambers asap. The porting i did should help flow out some.. gotta order some .039 felpro h/gaskets tomorrow. Will have pic,s soon 4 ya,ll.
08-22-2019, 06:51 AM | #17 |
You are calculating for dished pistons. He has domed.
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
08-22-2019, 08:28 AM | #18 |
08-22-2019, 11:31 AM | #19 |
guys my heads are 441,s and there 76 cc,s. there cut .010 but I unshrouded the 2.02 intake valves slightly to increase flow.
08-28-2019, 09:04 PM | #20 |
Cc,d my chambers, all was 75 to 77 cc,s. So 9.97 up to 10.19 compression with my combo. Perfect
08-28-2019, 09:19 PM | #21 |
Moderator
A 2 cc variance in chamber volume is just ok for street use...
I like to keep them below 0.5.... Your compression ratio is around 10 to 1...too high for the gruel served up at most gas stations....try premium and add octane booster.... and watch the timing lead....
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox |
08-28-2019, 10:43 PM | #22 |
It will be fine for 93 real gas, no alky. I,AM NOT BUILDING A RACE ENGINE
08-29-2019, 09:09 PM | #23 |
Hey BC,
I like what your doing with your build, this is going to help you tremendously. Check any info you may need here: https://www.crankshaftcoalition.com/...ategory:Engine I have flat tops in my stock engine with 76 cc heads. I can dial so much advance into it, most would call me ridiculous. With the domed pistons you will be into different territory. The one thing that concerns me is you have as much as 2 cc of differences in each chamber. My instinct does not like that with a higher compression engine. Keep in my your dynamic compression is what will dictate true running compression with the cam selection you make. My next build I want a bottom to mid range torque monster. With that in mind for a truck engine 2 topics came up with fellow engine buddies. Volumetric Efficiency, and Camshaft effective duration. A roller cam allows for more effective duration by design with less wear and tear. I want the most out of the motor without all the hp hype. That just tears up a motor. Will like to see how your build turns out. |
08-29-2019, 10:03 PM | #24 |
yea, this is the last flat tappet cam 4 me. roller from now on because of the poor quality oils now.
08-30-2019, 08:15 PM | #25 |
Heres some short block pic,s. ALL ARP FASTENERS , KING ROD N MAIN BEARINGS (THE BEST GOING NOW MADE IN ISREAL ) NEW FUEL PUMP, NEW MOTOR MOUNTS , MEW 8 INCH BALANCER NEW CLOYES DOUBLE ROLLER CHAIN N GEARSl aong with a howards reproduction lt1 350/370hp cam . SHOULD HAVE THE PAN ON IT BY TOMARROW EVENNING.
I BELIEVE IN JOHN 3:16 Last edited by BCOWANWHEELS; 08-30-2019 at 08:47 PM. |
