Old 10-31-2023, 09:51 AM   #1
RonWT
Active Member
RonWT's Avatar
Front coils, when to replace?
We have a 69 1/2- 2 wd that I am wondering about, we done a disc conversion, and replaced the shocks. New ball joints as well. The front end seems to clunk and seem really solid ride, the 1/2 tons I have had before seemed to almost float without all the noise from hitting bumps in the road. My question is could it be the springs are shot? Is there a tell tale way of knowing if I should replace them?
Thank you.
RonWT is offline   Reply With Quote
Old 11-01-2023, 11:56 AM   #2
SCOTI
SCOTI's Avatar
Re: Front coils, when to replace?
Thank you.
They can be worn/failing depending on how the truck has been used throughout it's life. An immediate indicator would be uneven heights @ each side. Ride quality would be another (too soft/too stiff).
If you feel they might be suspect, it can't hurt to replace them w/fresh parts.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
