Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 02-19-2006, 03:57 AM   #1
shortbed70
shortbed70's Avatar
Cheapest way to remove old bondo. IDEAS?
I'm getting ready to start the teardown process and strip all the old paint and mud off the truck and I don't have a compressor yet so how can I get started to remove some of the thicker areas of mud/paint?
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 02-19-2006, 04:03 AM   #2
ureckme
ureckmefixit2@cox.net
Re: Cheapest way to remove old bondo. IDEAS?
Electric grider with a paint buster disk. Harbor fright
That's U RECK ME FIX it 2
74 Chevy Short Bed
355ci Sportsman II 64cc Angle Plug
Crower Custom Grind .462in .486ex
Dyno Test 422hp @ 5600
And it's got a Holley
3.73 Gears
12 Bolt 3.73 w/Posi
700R4 Going In
I'm a Body Man So There!
That's why it's not painted
ureckme is offline   Reply With Quote
Old 02-19-2006, 10:19 AM   #3
cdowns
cdowns's Avatar
pretty much the way to go// the coarser the grit the better 40 or 60 will cut it quick DON'T FORGET A RESPIRATOR!!! or at the least a good dust mask and eye protection
Old 02-19-2006, 09:25 PM   #4
matthufham
yea, if you have a angle grinder, put a flapper disk on it and tear it up. actually it won't tear it up much, but it should take it down to bare metal really fast unless you have a bunch of dents. just be sure to wear a dust mask and stay out of the wind.
matthufham is offline   Reply With Quote
Old 02-19-2006, 10:13 PM   #5
shortbed70
shortbed70's Avatar
Yea thats what I thought. I need to get a bigger angle grinder and I can get my hands on some 60 grit at work. Thanks
Troy
Big Red Dog build
Old 02-27-2006, 01:46 AM   #6
revn67
revn67's Avatar
do you have access to a flame........burn it off and then take a scraper and it'll break right off
revn67 is offline   Reply With Quote
Old 03-09-2006, 08:40 PM   #7
grayw0lf
I prefer the wire wheel on the angle grinder. It rips through the bondo & doesn't load like sandpaper.
85' CUCV M1009!!! The newest addition!
6.2diesel, Th400, NP208, & only 36k miles!
70' C-10 LWB Fleetside - Looking good these days!
05' Dodge Neon
88' Winner Escape Sport 1750 - 4.3v6
94' Seadoo SP
84' Honda TRX200, bare nekkid. Just a frame & tires.
Always looking for another project or any good deal!
grayw0lf is offline   Reply With Quote
Old 03-12-2006, 03:14 PM   #8
matthufham
that's the worst smell i've ever smelled. it might be toxic to do that anyways. when welding i've set bondo on fire a couple times, but it does peel off easy when it cools.
Old 03-19-2006, 06:36 PM   #9
shortbed70
shortbed70's Avatar
Got the truck in storage building just in time for all this great weather were having in Kansas and will be getting started in the next couple of weeks. I'm in the process now of getting the wood floor out of it and the tailgate off and on stands then the bed... I'll get some pics tomarrow of the start...
Troy
Big Red Dog build
