Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 09-28-2020, 08:11 AM   #1
ffkg
Guest
Posts: n/a
WTB Automatic Transmission crossmember for 62 Longbed
Looking to buy an automatic transmission crossmember for my 62 C10 Longbed.
Thank you
Old 09-28-2020, 06:28 PM   #2
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: WTB Automatic Transmission crossmember for 62 Longbed
Thank you
Are you looking for original, or would you settle for aftermarket? Also, there's a thread on home fabricated ideas.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is online now   Reply With Quote
Old 09-28-2020, 09:47 PM   #3
Captainfab
60-66 Nut
What transmission are you wanting to run? The factory crossmember was designed for the Powerglide which will also work for a short shaft TH350
Old 09-28-2020, 09:56 PM   #4
ffkg
Guest
Posts: n/a
I was leaning toward a factory one. I was able to get ahold of a set of factory side motor mounts so was just going to continue that way .
That being said I would not be completely opposed to an aftermarket one as long as I didn't have to utilize my degree from MIT to get a legit install completed. Btw, thats the McGyver Institute of Technology not the super smart guy one.
Old 09-28-2020, 09:58 PM   #5
ffkg
Guest
Posts: n/a
TH350 is going to be the transmission.
Old 09-29-2020, 09:55 PM   #6
Captainfab
60-66 Nut
I have been trying to finish up reproduction auto trans crossmembers for the '60-'62 short wheelbase frames, but haven't been able to get them done. I do actually have a long wheelbase frame I could use for mockup. It depends on how big of a hurry you are in.
Old 09-29-2020, 11:30 PM   #7
ffkg
Guest
Posts: n/a
Not in a huge hurry at all. Im just on the parts gathering stage. What kind of a time frame where you looking at Cap?
Old 09-30-2020, 09:28 PM   #8
Captainfab
60-66 Nut
I have no idea at this point. I need to get the short wheelbase crossmembers done first as I have someone that has been patiently waiting for a long time.
Old 10-01-2020, 10:27 AM   #9
ffkg
Guest
Posts: n/a
Alright, please let me know when the time arrives.
Also along my searching i ran across a guy that is looking for a shortbed automatic crossmember so once you get that one dialed in you might have someone else ready for one. Im sure the actual list is pretty long.
Old 10-01-2020, 10:22 PM   #10
Captainfab
60-66 Nut
OK, I'll let you know.
Old 10-02-2020, 02:05 PM   #11
southern parts
southern parts's Avatar
Check with GMCNUT, he might be able to help.
southern parts is offline   Reply With Quote
Old 10-03-2020, 11:33 AM   #12
ffkg
Guest
Posts: n/a
Will do. Thanks
Old 10-26-2020, 10:30 AM   #13
ffkg
Guest
Posts: n/a
Still looking
Old 10-26-2020, 10:17 PM   #14
Captainfab
60-66 Nut
I'm hoping that in a week or so, I will be able to get my longbed frame brought over to my shop
Old 10-27-2020, 08:09 AM   #15
ffkg
Guest
Posts: n/a
Very cool.Can I put on a pre order?
Old 10-27-2020, 10:12 PM   #16
Captainfab
60-66 Nut
I'm not going to take any sort of deposit if that's what you mean. I have this thread marked and I'll try and keep you updated when I have some progress. I work 80hrs/7 days a week every week every month and I'll do the best I can. But I can not make any promises. Especially this time of year. If you find one somewhere else, you might want to consider that.
Old 10-28-2020, 08:01 AM   #17
ffkg
Guest
Posts: n/a
Ok,sounds good. Not trying to be pushy just wanted to let you know that I'm serious about buying one. If by some miracle I am able to find one then I will let you know. Thanks
Old 10-29-2020, 03:44 PM   #18
shortstep60
I am going to build some just drop of a factory crossmember of at my fab shop. Going to have them bend up a eight feet and laser the end caps for them. That way I can build long and short bed crossmembers. They are the same guys that made my rock guards I sale on the forum. They are busy so I don't no when I will have one done . Plus I want all of you to no I am not trying to take any work from captainfab he does great work.
shortstep60 is offline   Reply With Quote
Old 03-29-2021, 08:52 AM   #19
ffkg
Guest
Posts: n/a
Back on the hunt
Old 03-29-2021, 02:29 PM   #20
DPowers
One foot in front of the other
DPowers's Avatar
Check into a late 70's camaro xmember. May work for you.
DPowers is offline   Reply With Quote
Old 03-29-2021, 06:28 PM   #21
1960chevypanel
I have one, shoot me a PM
1960chevypanel is offline   Reply With Quote
Old 03-31-2021, 11:21 PM   #22
j.kirn
Aspen auto just listed 1
j.kirn is offline   Reply With Quote
Old 04-18-2021, 10:59 PM   #23
67 swb
ffkg.. whats the deference in the short bed vs long bed crossmember..
67 swb is offline   Reply With Quote
Old 04-18-2021, 11:43 PM   #24
ffkg
Guest
Posts: n/a
As far as I know the longbed crossmember is longer due to the difference in the frame compared to the shortbed.
I'm sure one of the more knowledgeable members on here could give you a more accurate explaination, that's just my understanding.
Old 04-18-2021, 11:47 PM   #25
67 swb
I know the long box one will fit in a short box frame.. i used a 3/4 longbox crossmember on my short box.. Any idea what a longbox crossmember sells for..
