Old 11-09-2021, 11:48 AM   #1
ls1nova71
ls1nova71's Avatar
6l80 to NP205 shifter issues...
Anyone on here put an NP205 transfercase behind a 6l80 with an Advance Adapters kit? It looks like a nice adapter, but there's no where to bolt the shifter to it.... Wondering if someone has come up with a solution before I start fabricating some kind of a mount on my own.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 11-10-2021, 06:04 PM   #2
6600DURAMAX
6600DURAMAX's Avatar
Re: 6l80 to NP205 shifter issues...
Not to hyjack the topic but how are you shifting your 6L80E?
My 6L80 has a 208 behind it and I plan on using a shift kit from JB Customs -
jb-customs-fabrication.myshopify.com They do have a NP205 kit for $278
1972 K5 Build - plans - LS3-6L80e-One Tons.....
1971 CREWMAX Build.....at body shop for couple more years
6600DURAMAX is offline   Reply With Quote
Old 11-12-2021, 11:16 AM   #3
ls1nova71
ls1nova71's Avatar
I haven't gotten to the transmission shifter yet, but that looks pretty straight forward other than the long tube header in the way. I'm thinking of just using a Lokar adjustable shift linkage on it.
I have heard about the JB Custom cable shifter, that's what Advance Adapters said to use, but to run the 205 I'm pretty sure you would need the twin stick with 2 shifters and 2 cables, none of which I'm a fan of. Going to try and fab up something I guess since it appears no one has done anything like that yet, so there's no off the shelf answer.
Old 11-12-2021, 05:41 PM   #4
mongocanfly
mongocanfly's Avatar
saw this
most of what i saw was some version of twin sticks, (air ,elec, cable, or levers)
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 01-29-2022, 11:17 PM   #5
HotRod4me
I used roughly the same same set up on mine. L96/6L90 with an Advanced Adapter kit. I wanted to keep the stock appearance and not add a twin stick set-up. I had to cut down the 6L90 out put shaft and add a 3/4" spacer to the adapter, so I would have enough splines in the transfer case output shaft. Used 2" flat stock and formed it around the curve of the adapter. Then welded on some sides and a plate to bolt it in 2 places on the transmission tail. Used a couple spacers to get the correct fitting and extended the arm to the transfer case about 1-1/2", so the stock shifter would sit at the correct angle.
HotRod4me is offline   Reply With Quote
Old 01-30-2022, 12:46 PM   #6
ls1nova71
ls1nova71's Avatar
Yeah, I ended up doing roughly the same thing. Its not pretty,, but looks like it is going to work out fine.
Old 01-30-2022, 09:12 PM   #7
HotRod4me
Looks good!!
I was happy with the Advanced Adapter kit, but they sure could do a better job with shift arm mounting options.
I've gotten a lot of tips that have pointed me in the right direction from your previous postings. Keep up the good work.
