08-10-2016, 05:49 PM | #1 |
Reverse Light Switch
Anyone have a part number for this piece?
Its from a manual tranmission, 3 on the tree. Off the column. I don't see any on RockAuto. I figure I would like to keep the switch in the cabin. I might try to replace the plastic toggle with an aluminum piece. and have the aluminum toggle push a momentary mounted to the side of the metal piece. Obviously unless I can just buy a replacement.
1968 GMC truck 910 Trim (Canadian) 127" WB 3 on the Three Trans (Saginaw SM330) 250 ci L6 Engine HEI ignition (early 80s L6) |
08-10-2016, 09:04 PM | #2 |
Re: Reverse Light Switch
Not sure of a part number, but I bought mine from LMC.
Bill 2004 Chevy Silverado Z71 Ext Cab 1500 1972 Chevy K-10 SOLD 1967 Chevelle SS |
08-10-2016, 09:14 PM | #3 |
36-0661 lmc
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T |
08-10-2016, 11:25 PM | #4 |
I have one I'll send you if you can find me the part number for the other version with the back up light switch in it. I've got a tilt collumn and need a switch for it. Just pm me
My Build Thread Here http://67-72chevytrucks.com/vboard/s...d.php?t=457417 |
08-11-2016, 06:55 AM | #5 |
I found one (3 were in stock). They weren't charging outrageous prices either.
2 Left at; www.autopartsobsolete.com
