03-14-2018, 12:40 PM | #1 |
Active Member
WTD Blazer Top-Windshield Brackets,Hatch Handle & Struts
I would like to buy:
2 blazer brackets that go on top at the front to bolt to windshield frame. Used Hatch handle and lock with hardware mechanism to connect to rods 1970 Green (Aqua) Blazer Pass. Side seatbelt retractor |
03-14-2018, 02:32 PM | #2 |
Re: WTD Blazer Top-Windshield Brackets,Hatch Handle & Struts
I have the windshield brackets, looks like you need struts also, do you need the ones that hold the hatch up?
03-14-2018, 02:37 PM | #3 |
Active Member
03-14-2018, 10:54 PM | #4 |
Here are the top brackets I will get a picture of the struts this weekend.
03-14-2018, 11:14 PM | #5 |
Active Member
03-15-2018, 10:30 PM | #6 |
Here is the hatch struts I should have got a picture of the mounting bracket on the left side. Look at the top bracket on the left side the one is a egged out a little I think it will be fine with the correct bolts. 80 for the struts 30 for the top brackets plus shipping and I will include the correct bolts for the struts.
03-15-2018, 10:31 PM | #7 |
I can get a better picture of the bracket if you like.
03-15-2018, 11:05 PM | #8 |
I will get you a shipping quote tomorrow. I just bought some latches but hate to split up a pr. I will look and see if I have a single.
03-17-2018, 05:54 PM | #9 |
Here is a left latch (drivers side) that I replaced the spring in. I drill the end of the rivet off replace the spring and tack the end to keep it in place. 40 for the latch and everything will fit in a medium flat rate for 14
03-17-2018, 06:14 PM | #10 |
Forgot I found this looking for the latch do you need one of those also
03-17-2018, 09:40 PM | #11 | ||
Active Member
I will take both. Give me a total and address for paypal to. Thank you for tracking it all down. |
03-17-2018, 10:50 PM | #12 |
03-17-2018, 11:02 PM | #13 |
PP received will box up tomorrow and should ship Monday.
