12-14-2007, 04:09 PM | #26 |
K5-2WD=C5
Re: my 1970 blazer build=4wd to 2wd
each seat was about $40.00 (each bucket, and the rear bench) and the brackets were 2.00 a piece. so i paid like $150. here's a better pic of the bracket.
12-14-2007, 07:22 PM | #27 |
C10 Club Tennessee
those are the same ones that I have for my blazer. I bought my seat from jkade and he cut the four brackets out of the floor for me. Looking forward to seeing what they look like in yours.
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
12-15-2007, 11:27 AM | #28 |
If you go with the 4 link you can get it to go lower b/c you don't have the frame hitting the trailing arms. It isn't any more difficult. I just converted my 4x4 to a 2wd recently. Check out the pics of the 4 link and a pic of my 4x4 to 2x4 blazer.
12-15-2007, 02:56 PM | #29 | |
2wd FTW!!!!
12-15-2007, 07:34 PM | #30 | |
K5-2WD=C5
that looks much harder to do than installing the factory trailing arms? is that a kit already made or is it custom? also i dont think im going to go that low.. yours looks good! a lower profile tire might look even better!!! i already got the trailing arms (thanks fleetsidepaul!), im still looking for my crossmember.. |
12-15-2007, 08:05 PM | #31 |
K5-2WD=C5
today i pretty much got my front bucket seats mounted. i still need to fill-n'-drill weld the nut brackets to the bottom of the floor. i had to customize the floor a little to make them work. i had to flatten parts of the dip in the floor pan where the two inner bolts go (on both sides), by cuting a small section and hammering it straight then welding it back together. then i drilled my holes.
12-16-2007, 04:03 AM | #32 | |
12-17-2007, 08:00 AM | #33 |
K5-2WD=C5
finally got my seats mounted! whew! took forever, but they came out goood! i used the same brackets that go with the seats, once again my chisel and hammer were a big part here in getting these from the pick a part. i drilled holes and filled them with weld to hold them in place. just like the factory.
12-17-2007, 08:19 AM | #34 |
A guy with a truck
Seats look good. Are you gonna remove the headrests?
Here's a few pics of what I did for the fuel filler on my pickup. The same concept will work for your Blazer. I just used the late model filler and covered it all inside the bed with a Blazer filler cover. To get the neck under the bed, I cut off the stock bend and welded on a piece of pre-bent exhaust tubing from the parts store. Used fuel filler hose to connect to the tank- works like a charm...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
12-20-2007, 08:19 PM | #35 | |
K5-2WD=C5
Thanks everyone for the gas filler neck pics, the did help! i wanted to make something 100% water proof to the interior. im really happy with the way it turned out. it took about three full work days thinking plus fabricating. the outside is still not fully welded and the back only has a few tack welds, but i am going to fully weld it still! |
12-20-2007, 08:23 PM | #36 |
K5-2WD=C5
01-06-2008, 08:38 PM | #37 |
2wd FTW!!!!
any thing new on this?????
01-07-2008, 02:48 AM | #38 |
The LuvShack Garage
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
01-07-2008, 04:06 PM | #39 |
K5-2WD=C5
hmm lets see, there sure is, i left off fully welding the gas filler design.
the antenna hole got plugged. some parts pics back seat for the most part is done as well, i still want to weld and grind from the bottom of the truck before installing the seat brackets |
01-07-2008, 04:12 PM | #40 |
K5-2WD=C5
my feet are near the front of the truck Last edited by toplesskayfiver; 01-08-2008 at 12:46 AM. |
01-07-2008, 04:31 PM | #41 |
Nice work on the gas filler neck, enjoying your thread. J.
01-08-2008, 09:46 AM | #42 |
That is one very clean and well thought out mod for the rear seat mounts. Depending on how big my rear notch ends up being I might go the same rout.
Kevin LFD Inc. |
01-08-2008, 10:28 AM | #43 |
Once it's finished, it will look almost factory. Good job!
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
01-08-2008, 11:37 AM | #44 |
A guy with a truck
Me too. Slick!
01-09-2008, 04:34 PM | #45 |
K5-2WD=C5
Thanks, im glad you guys are tuned in!
im a sucker for factory style stuff that looks good and works good Last edited by toplesskayfiver; 01-10-2008 at 11:17 AM. |
01-10-2008, 09:15 AM | #46 |
That is some very nice work!
02-06-2008, 06:57 PM | #47 |
K5-2WD=C5
dash upgrade!
got the rockers welded up finally. and i used all new body mounts to align everything (doors mostly) before i separate the frame from the body, nothing is perfect yet but PRETTY DARN CLOSE! when it goes back together AGAIN i will make sure everything is PERFECT! the driver door looks like a reproduction but it just covered in overspray im using 100 percent gm parts Last edited by toplesskayfiver; 02-06-2008 at 06:59 PM. |
02-08-2008, 08:09 AM | #48 |
2wd FTW!!!!
Cool Looking Good!!!!!
02-08-2008, 03:55 PM | #49 |
Cochino_Racing_909
NIce Work where in CA are you I am in the IE also
02-08-2008, 11:57 PM | #50 |
Really coming together nicely. Not sure if you mentioned it before, what color will it be?
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
