05-03-2019, 06:49 PM | #1 |
BlahBlahBlah
A little help from you "late model" guys please
So this is just a pure guess on my part, but can someone here tell me if this is a cruise set up for one of the years represented on this side of the board please? And if it is can you tell me if its OEM or aftermarket ... thanks!
Click the link for a ginormous pic from my board member gallery ... http://67-72chevytrucks.com/gallery/...hp?photo=45800
… … … … … … … … ... … … … … … … … … … … … Monroe Swap meet May 18-19. Mike has the same spots for the NW guys he's had forever. Lunch time BBQ at the spaces. If you have stuff to sell bring it along. If you have a question PM stllookn (Mike) here via the board. https://67-72chevytrucks.com/vboard/...d.php?t=851291 |
05-03-2019, 08:12 PM | #2 |
Re: A little help from you "late model" guys please
Looks to be from an 85? or newer.
I'd have to go look at mine to be sure. Mike. |
05-03-2019, 10:20 PM | #3 |
Some of the parts look similar to what was on our 85, but the cruise stalk is different
05-03-2019, 10:33 PM | #4 |
BlahBlahBlah
Good info so far, thanks for chiming in guys.
05-03-2019, 11:01 PM | #5 |
Looks exactly like the cruise system I recently pulled off my 85. Best thing I ever did removing all that outdated, unreliable crap! Replaced it with a simple Dakota Digital setup.
05-04-2019, 12:40 PM | #6 |
Actually, I dont think it's from an 85. Eventhough it's got resume and such, the stalk where it mounts inside column does not push/snap in (like an 85) it looks like it has a screw hole for mounting.
I would say late model set up with an early mounting stalk. (Before moving dimmer to column)
Jay Gesner Atlanta, GA 1985 C10 Long Bed 4X2 LS 5.3, 4L60E Father/Daughter Project |
05-04-2019, 04:21 PM | #7 | |
BlahBlahBlah
05-04-2019, 07:23 PM | #8 |
I took a longer,closer look and I believe it's from an 82 model.
I went and looked at my 82 (bought it new) and all the parts appear to be the same. It's not any newer because the newer ones have the wiper,dimmer,turn signal and cruise all in the the same control on the turn signal arm.Or, some combination of those devises. Mike. |
05-04-2019, 08:20 PM | #9 | |
BlahBlahBlah
05-04-2019, 09:55 PM | #10 |
my 81 has that same style cruise control. If I remember correctly they only used it for a few years 79-83?
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 |
05-05-2019, 09:27 AM | #11 |
Moderator
If this system was installed on your 1985 truck it's not stock.
That's a Cruisemaster transducer system with resume. GM used them from 1968 through 1980 or 1981 or thereabouts. The resume function was the last few years and AFAIK was not used on the light trucks. It could be retrofitted if one has a complete setup like you have there. The dead giveaway is that Cruisemaster used a mechanical transducer inserted in the speedometer cable. It's in the lower left corner of the picture. The pre-1984 screw hole stalk is another dead giveaway. Last and not least is the vacuum only pod. You can still get parts for the Cruisemaster systems. 1982-1990 Cruise III not so much... The older Cruisemaster system was far more reliable than the short lived mid 80's Cruise III systems that used an embryonic electronic controller and electrically connected vacuum pod. Cruisemaster was easier to retrofit as well. If you dig into the dash the Cruise III systems have a green or yellow VSSB with an optical pickup in the speedometer. 1982ish-1990ish Cruise III vacuum pod. This is a 25111880 Cruise III controller. and a similar 25074714 Cruise III controller board... The Cruise III controller and VSSB used PakCon connectors to slip over the end of the printed circuit board like an Atari 2600 or Nintendo game console cartridge. Even without 40 year old electrolytic caps the VSSB and Controller boards are open to the atmosphere so they collect conductive dirt and grime and can get more than a little schzophrenic. Cruise III also has several vacuum lines with a vacuum accumulator ball, check valve, vacuum release valve on the brake pedal and other assorted vacuum goodies just to add more reliability to the system
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. Last edited by hatzie; 05-05-2019 at 10:00 AM. |
05-05-2019, 11:01 AM | #12 |
BlahBlahBlah
Well whatever it works out to be in the end I have zero use for it. It might be a high value set up or it might be a zonk. Ill offer it up for free if anyone here wants it. Ill ship it in the smallest USPS box it will fit in. Just pay for shipping.
Please no PM's ... First I want it here in this thread gets it. We can go to PM from there.
05-05-2019, 02:39 PM | #13 |
And I stand corrected. Didn't look close enough.
05-05-2019, 07:41 PM | #14 | |
I might be able to make it work on my 82,C-30,car hauler truck. Thanks,Mike. |
05-05-2019, 07:49 PM | #15 |
BlahBlahBlah
Ok Mike shoot me your name and address via PM. Ill stop at the post office in the next couple of days and grab a couple boxes. Not sure which one it will fit in yet.
05-05-2019, 08:21 PM | #16 |
05-10-2019, 11:01 AM | #17 |
BlahBlahBlah
Mike I finally got the parts all boxed up and ready to go. Dropping them off at the post office today along with some parts for a couple other fellas.
Two things ... If it turns out these are incredibly valuable please remember me in your will. And just a warning to a fella that goes by 100%Chevy ... Im dropping them off in my Ford ... ahhhhhhhhhh! Hope they are something you can actually put to use =) Mark PS: Im covering the shipping, but like I said, remember me in your will =)
… … … … … … … … ... … … … … … … … … … … … Monroe Swap meet May 18-19. Mike has the same spots for the NW guys he's had forever. Lunch time BBQ at the spaces. If you have stuff to sell bring it along. If you have a question PM stllookn (Mike) here via the board. https://67-72chevytrucks.com/vboard/...d.php?t=851291 Last edited by CG; 05-10-2019 at 12:23 PM. |
05-10-2019, 01:55 PM | #18 |
Thanks,Mark!
I'll try to wash the Frod smell off! I'm not sure how valuable the parts are ,but they have value to me! I will definately use them!My 82,C-30 needs a speedo cable and housing.These parts will fit in the same place,so you've already saved me that cost .And,the servo is always going out on this type cruise unit,so if it's still good,I can use it too. Very kind of you to also cover the shipping,although I'd be more than happy to pay it. Or,if I have anything parts wise you may need,just ask.I have more than 25 GM trucks here,10 are square bodies. As far as my will goes,you're in! (somebody has to pay the bills i leave behind!LOL!) Thanks again,Mike. |
05-17-2019, 09:21 PM | #19 |
BlahBlahBlah
Just checking in to make sure you got the box.
05-17-2019, 10:21 PM | #20 |
This type of Crusie Control, more commonly called "Transducer" was on Square Bodies from 1983 under!!! 1984 had a completely new system.
05-18-2019, 09:58 AM | #21 |
CG, I did get it on Tuesday of this week!
I'm sorry, I didn't post it here sooner. We've been trying to deal with my late brothers estate and the financial end isn't going well at this time,so, a lot of sitting ,waiting in their offices,etc. That is a well packed box!You should work for Santa Clause with your skills! I took the parts out to look at them,but can't get them back in it.thank you again! Mike. |
05-19-2019, 01:20 PM | #22 |
BlahBlahBlah
Ok, cool beans. Just making sure they arrived.
Sorry bout your bro, these things are always tough.
05-24-2019, 07:23 PM | #23 |
BlahBlahBlah
Mike! Got an envelope in the mail today. Much appreciated, but really, I was totally 100% happy with our deal.
You're a good man ... thanks buddy!
05-24-2019, 08:05 PM | #24 |
You're welcome!
I've been fortunate in my life.I've met many good people. I try to be one myself and I know you are one too! And,thank you too! Mike. |
