Old 02-28-2020, 03:33 PM   #51
makman1297
makman1297's Avatar
Re: Dad's Dodge
And a little more.
1981 Dodge D-150 (under construction)
2007 Chevy Suburban
2010 Dodge Charger R/T
1980 Kawasaki KZ 440
2004 Harley Sportster 1200
makman1297 is offline   Reply With Quote
Old 02-28-2020, 03:36 PM   #52
makman1297
makman1297's Avatar
Re: Dad's Dodge
I started stripping and prepping the top of the cab, lots of surface rust and dried out sealant in the seams. I found one rust hole above the drive that welded a patch over. I put in a couple of late nights this week and was able to shoot a coat of primer over it.
2007 Chevy Suburban
Old 02-28-2020, 03:41 PM   #53
makman1297
makman1297's Avatar
Re: Dad's Dodge
I was able to knock out a lot of little things too. Rebuilt the master cylinder, modified/fixed the throttle cable and kick down linkage, wired new tail lights/reverse lights, installed receiver hitch, mounted cab, made an ignition coil mount.
I plan to mount and do final fitment on the doors tomorrow and then prep them for paint.
2007 Chevy Suburban
Old 02-28-2020, 04:46 PM   #54
mongocanfly
mongocanfly's Avatar
Re: Dad's Dodge
,looks like your moving right along..good luck with the paint..!
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 02-29-2020, 03:38 AM   #55
makman1297
makman1297's Avatar
Re: Dad's Dodge
Thanks mango. I am moving in June so I need it back together to help move.
2007 Chevy Suburban
Old 02-29-2020, 09:56 PM   #56
makman1297
makman1297's Avatar
Re: Dad's Dodge
Fitting doors and dr fender. I decided to replace the Lh fender since it had more rust than I though. I had to adjust the dr door repair and aftermarket fender to get the gaps right.
2007 Chevy Suburban
Old 02-29-2020, 09:59 PM   #57
makman1297
makman1297's Avatar
Re: Dad's Dodge
I had to cut the speaker hole bigger to fit the new speakers too, lol.
2007 Chevy Suburban
Old 04-12-2020, 04:42 PM   #58
makman1297
makman1297's Avatar
Re: Dad's Dodge
Body work continues.
2007 Chevy Suburban
Old 04-12-2020, 04:45 PM   #59
makman1297
makman1297's Avatar
Re: Dad's Dodge
And more body work. Also installed the fuel filler and vent tubes.
2007 Chevy Suburban
Old 04-12-2020, 04:50 PM   #60
makman1297
makman1297's Avatar
Re: Dad's Dodge
Busy at work. Rear glass installed, the Jedi master came out to the shop. She always helps with the glass installation on all of my projects. Also found that the Mopar radiator shroud for a 73 cuda big block fits perfect.
2007 Chevy Suburban
Old 04-12-2020, 04:53 PM   #61
makman1297
makman1297's Avatar
Re: Dad's Dodge
Final block sanding revels all secrets.
2007 Chevy Suburban
Old 04-12-2020, 04:56 PM   #62
makman1297
makman1297's Avatar
Re: Dad's Dodge
Paint time. Also found a windshield in Savanah. Some assembly required.
2007 Chevy Suburban
Old 04-12-2020, 04:59 PM   #63
mongocanfly
Re: Dad's Dodge
looking good
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 04-12-2020, 04:59 PM   #64
makman1297
makman1297's Avatar
Re: Dad's Dodge
Assembly continues. Wet sanding and buffing too. I had to perform some mirror surgery to get them to angle correctly.
2007 Chevy Suburban
Old 04-12-2020, 05:03 PM   #65
makman1297
makman1297's Avatar
Re: Dad's Dodge
Windows installed. Door panels painted. I am waiting on parts and continue to assembly as time permits. I need to buff the clear a little more as I have some dull spots still.
2007 Chevy Suburban
Old 04-20-2020, 03:45 PM   #66
Russell Ashley
Russell Ashley's Avatar
Re: Dad's Dodge
Coming along nicely. Paint looks great. It's a smart move to have the whole family involved.
Russell Ashley is offline   Reply With Quote
Old 04-21-2020, 07:11 AM   #67
Re: Dad's Dodge
Truck is coming together very nice! Love the color.
Old 04-24-2020, 09:25 PM   #68
67C10Step
67C10Step's Avatar
Re: Dad's Dodge
Nice. Love the green.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2020 Toyota CH-R
2020 Acura MDX
67C10Step is offline   Reply With Quote
Old 04-25-2020, 04:59 PM   #69
mongocanfly
Re: Dad's Dodge
Thanks..!!!
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 05-21-2020, 09:23 PM   #70
makman1297
makman1297's Avatar
Re: Dad's Dodge
Thank you Mongo, 18 years and counting. Getting close to retirement.
I have pushed and got a lot of work done, some times I think I rushed in some places and have to pay for that. At the end of the day we learn new skills everything we do something and make a better product the next time.
2007 Chevy Suburban
Old 05-21-2020, 09:29 PM   #71
makman1297
makman1297's Avatar
Re: Dad's Dodge
The work continues, but my china freight air compressor had a melt down so I had to find something else to finish my painting.
2007 Chevy Suburban
Old 05-21-2020, 09:30 PM   #72
makman1297
makman1297's Avatar
Re: Dad's Dodge
I also decided to try my hand at pinstriping. Also had to do some spedo work, these old spedos are not so great.
2007 Chevy Suburban
Old 05-21-2020, 09:38 PM   #73
makman1297
makman1297's Avatar
Re: Dad's Dodge
Front end done and hood aligned as close as it gets. I am thinking the body lines were not as much as a concern back then. I also changed out the water neck to add a thermo valve to control the ported vacuum operating the charcoal canister.
2007 Chevy Suburban
Old 05-21-2020, 09:42 PM   #74
makman1297
makman1297's Avatar
Re: Dad's Dodge
I also decided to add catalytic converters to aid my move to another state, plus they help keep down the stink with a carb.
2007 Chevy Suburban
Old 05-21-2020, 09:48 PM   #75
makman1297
makman1297's Avatar
Re: Dad's Dodge
Washed the truck today and took some photos for my aunt. She wanted to see what it looked like when we were done. I put 150 miles on it so far, had a little carb tuning to do. I also swapped to a lokar throttle and kick down cable, they are an amazing improvement. The kickdown levers on these things are a real pain and the cable makes it much easier.
I have some drive line work to do, it has some vibs at 60 mph.
This was a great father and son project, now it time to fine tune this puppy and enjoy the ride!
2007 Chevy Suburban
