10-20-2013, 03:55 PM | #9 |
Re: dilema
You need a 12 volt signal going back to the ECM when the brakes are not applied. This should hook up to a two position brake switch and once you hit the brake pedal it will stop the signal. The switch you need should be from a 84 with cruise.
1949 Five Window, 1973 Step Side, 2000 Z71 |
