03-12-2019, 11:41 PM | #1 |
Rad for 65 with upper hose on ps?
I sure don't like the way the upper hose goes all the way over to the ds of the radiator like I see in so many other 63-66 LS swaps. Plus it interferes with routing the air intake toward the ds. Is it possible to get a rad with the upper inlet on the ps? Would it lose efficiency to have upper and lower on the same side? Does someone make one for the 63-66?
03-13-2019, 02:11 AM | #2 |
Re: Rad for 65 with upper hose on ps?
("I sure don't like the way the upper hose goes all the way over to the ds of the radiator like I see in so many other 63-66 LS swaps. Plus it interferes with routing the air intake toward the ds. Is it possible to get a rad with the upper inlet on the ds?")
did you mean pass side? you can run air intake to pass side...run under the rad. hose like this
03-13-2019, 07:22 AM | #3 |
Sorry ya I meant passengers side. Wondering if it’s possible to run the upper hose to the passenger side of the rad and run the air intake to the drivers side.
03-13-2019, 07:35 AM | #4 |
If your gonna pull and return on the same side of the radiator, youd be better off with a cross flow split style..
03-13-2019, 08:39 AM | #5 |
03-13-2019, 11:20 PM | #6 |
60-66 Nut
These guys will build you a radiator just how you want it.
http://www.67-72chevytrucks.com/vboa...d.php?t=591690
03-18-2019, 09:44 PM | #7 |
Entropy sells what you are looking for but get your wallet ready
http://www.entropyrad.com/1963-1966-...-radiator.html |
