01-25-2019, 10:57 AM | #1 |
85 C10 LT/6L80 Frame off build
I decided to swap my truck from LS/4L85 to an LT/6L80 back in October of 2018, it didn't take long for it to spiral out of control. I thought I would share my build as I work on it. Hoping to have it complete by July 2019
01-25-2019, 07:36 PM | #2 |
Re: 85 C10 LT/6L80 Frame off build
Interesting. Most guys would be just fine w/the LS/4L85 combo especially one that looked as nice as what was under your hood.
01-25-2019, 08:49 PM | #3 |
That truck is so clean
01-25-2019, 09:43 PM | #4 |
I’m just bored with the LS. Want a 6 speed and wanted to update the truck. Engine and trans went to good use in a friends C10
QUOTE=SCOTI;8450988]Interesting. Most guys would be just fine w/the LS/4L85 combo especially one that looked as nice as what was under your hood.[/QUOTE] Posted via Mobile Device |
01-27-2019, 10:18 PM | #5 |
Sheetmetal work happening now, due to some repairs 15 years ago I'm going to change out the doors and doghouse for some nice original paint doors, fenders, and hood. box of hardware going out for zinc plating. hoping to be doing body work in the next week
01-30-2019, 04:24 PM | #6 |
The Peacemaker
Glad to see someone else doing an LT build. But I am curious as to why you chose the 6spd auto over the 8spd or a manual for that matter. Keeping it a column shift or doing a floor shift?
1978 Chevy 2wd Stepside aka "Audrey" Cordova brown with mandarin guts 79k original miles & being restored 1979 Chevy 2wd Short Wide aka "Emma-Jayne" Cordova brown with mandarin guts 2019 Chevy Tahoe LT Previous rides: -2002 Firehawk T/A, 2006 Trailblazer SS AWD, 2014 GMC Sierra RCSB, 1971 2wd Blazer, 1996 SNB, 1997 2dr 2wd Yukon, 2001 Silverado RCSB, 2011 Silverado Z71 4x4, 1982 2wd Blazer, 1997 2dr Tahoe, 1970 Chevelle SS, 1972 2wd Blazer, 1986 Silverado Stepside, 1995 S-10, 1985 Silverado SWB. |
01-30-2019, 04:30 PM | #7 | |
Why not a 6L80? it will be much better than the 4L85E that I had. Also I'm not sold on the 8L yet, most I have driven make a lot of noise clunking around. A T56 magnum would have been nice but the cost really adds up to do that. I will keep it column shift with the OE shifter rod assembly |
01-30-2019, 06:46 PM | #8 |
I really dig that truck - super clean. I like the stance and wheel tire combo as well.
02-01-2019, 08:08 PM | #9 |
Love the setup(s) and the truck is clean as hell. excellent work. I found a 6.2 and 2wd 6l80e, with harness, accessories, and driveshaft, out of a 2012 silverado with 116k miles for 5 grand. Been thinking all day about changing out my cammed L33 and 4l65.
I read some people saying the 6l80 isn't as strong as a 4l80 and can't hold much more than 400hp. Any concerns with yours? or are you staying relatively mild with the LT?
Greg 1974 GMC 1/2 Ton SWB Fleetside L33 5.3/4l65e .................__
............._____l __\__ ..............l_(O)_ l___(O)] |
02-01-2019, 10:36 PM | #10 | |
03-07-2019, 11:06 AM | #11 |
anyone have a 81-87 damage free OE hood near bowling green KY?
04-11-2019, 07:41 AM | #12 |
new Sheetmetal fitted and ready for some small repair work, sending all the hardware off for clear zinc coating
04-12-2019, 08:13 AM | #13 |
Rear-end build time, for years I've been using Richmond gears with no issues. I like how they have the pinion depth on the pinion head, makes set up much easier. I will also be using their Richmond Excel axles and set-up kit to freshen up the 30 year old 12-bolt.
Richmond 3.42 gears 49-0070-1 Richmond set up kit 83-1018-1 Richmond Excel axles 92-25192 |
04-12-2019, 09:36 AM | #14 |
Nice parts.
04-12-2019, 09:53 AM | #15 |
I am curious- what is the reason for all the body rebuilding - in the pictures the truck looks really sharp already. The Paint appears to be nice as well!
04-12-2019, 10:49 AM | #16 |
Thanks for asking Matt, I built the truck and did the body/paint work back in 2002. The truck still looked really good but there were several issues I wanted to fix and it just made sense to start over with some nice OE paint sheetmetal and pass the old panels on to someone else that could use them.
04-12-2019, 10:49 AM | #17 |
04-15-2019, 09:31 AM | #18 |
Primer #2 is complete, using all Tamco products on this build. if you are a body man and haven't used Tamco primer you are missing out!
04-15-2019, 11:02 PM | #19 |
what primer from tamco did you use? im gonna spray some 5311 this week, first time using their products
04-16-2019, 07:39 AM | #20 |
05-16-2019, 10:11 AM | #21 |
rear-end build complete
05-16-2019, 10:16 AM | #22 |
sent the frame off to powder coat while I painted the control arms and things that couldn't be powder coated. pretty happy with the finished results!
08-23-2019, 12:42 PM | #23 |
Any updates on the build?
"Dixie" - 1988 Chevrolet V30 CC DRW "3+3" | 7.4L 454 (L19) | TH400 | 4" lift | 35"s "Lucille" - 1949 Chevrolet 3100 (on hold) |
08-23-2019, 01:40 PM | #24 |
08-23-2019, 02:09 PM | #25 |
I looked @ your build thread on LS1.com. Kind of figured you were going bigger than the L83 since you already had a 6.0.
I highly recommend swapping out your rag-joint set-up for a Cherokee XJ shaft swap. I chimed in on pg.2: http://67-72chevytrucks.com/vboard/s...=505196&page=3
