Old 12-30-2020, 02:06 PM   #601
pdxhall
pdxhall's Avatar
Re: 1965 LWB Stepside Build
very nice interior work. I also love the shifter and the Indian knob.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 01-05-2021, 12:13 PM   #602
roll_the_dice
roll_the_dice's Avatar
Thanks! I appreciate it. Everytime I shift gears, I love the Indian knob more.
roll_the_dice is offline   Reply With Quote
Old 01-05-2021, 12:28 PM   #603
roll_the_dice
OK, so I took my truck back into the shop that did my A/C work...the A/C isn't working. THe compressor isn't coming on...I think it is either too much freon or not enough. Anyway, they are going to fix it...and there were runs in the dash clear coat that they are going to clean up which should have been done before I got it back.
While the truck is gone, I thought I would look at my spare tire hanger. Fortunately being a LWB I don't need the fender cutout, but it is going to be a close fit so it will have to be hung exactly in the right spot. I have on original stepside hanger for a 6 lug wheel. My truck was converted to 5.
The top stud on the hanger could/should work fine...do I just cut off the other 2 studs and weld 2 new studs in place or cut off all 3 studs weld a slightly larger piece of metal on and then weld 3 studs in place?
Old 01-16-2021, 07:51 PM   #604
roll_the_dice
Ordered new PML valve covers today...Can't wait to get them so I can paint them and install...going to dress up the engine bay so good. Got them from www.lyonsperformance.com on a great deal...saved about $150!
this ppicture is from www.yourcovers.com (PML)...the great deal was on "corvette" covers...going to paint them light green to match the other bits in my engine bay.
Old 01-24-2021, 01:06 AM   #605
roll_the_dice
OK, so I started driving the truck at Thanksgiving...had 360 hundred miles on it when we left today. Took it out on it's mayden day trip today...we did about 250 miles round trip...have 609 miles on the truck now! Did some pictures...just cruised and had fun. Truck did great. Here are a few pictures from the trip.
Old 01-24-2021, 01:24 AM   #606
roll_the_dice
Here are some more my wife took.
Old 01-24-2021, 01:30 PM   #607
J Williams
J Williams's Avatar
That’s awesome man! Truck looks great, can’t wait to drive mine around like that! Such a fun time driving the old trucks around
63 C10
J Williams is offline   Reply With Quote
Old 01-24-2021, 02:38 PM   #608
The Rocknrod
Moderator
The Rocknrod's Avatar
Nice work.
Old 01-25-2021, 11:41 AM   #609
roll_the_dice
My wife made this comparison picture...one before the restoration started and one this weekend...quite the difference in the interior dash.
Old 01-25-2021, 08:03 PM   #610
cwcarpenter98
cwcarpenter98's Avatar
Heck yeah man! All that hard work payed off!
Christian Carpenter
1963 C10 - Frankentruck 283, 3 speed with overdrive
Overdrive wiring here
1981 C10 - Penny 305, th350
1995 Dodge Dakota Sport
Old 01-25-2021, 11:36 PM   #611
roll_the_dice
Thanks Christian!
Old 01-25-2021, 11:44 PM   #612
roll_the_dice
Started painting my new valve covers today...will get finish up in the next few days...going to get some black on it tomorrow.
Old 01-26-2021, 07:40 PM   #613
350TacoZilla
Looks great man! good to see you getting it out and enjoying it. On the spare tire thing I would put 3 new studs in that are same thread as your lugs and mount the spare using 3 lug nuts like what the truck uses, that way if you need to change out the tire alongside the rd and drop a lug or two you have spares. Heck even if you drop all 5 you will have 3 and can throw the flat in bed. I would also make a secondary lock that is easy to use but hard to defeat if you know what I mean, a simple plate with loop sticking through that covers the lugs is effective. I like the puck lock type of system.
350TacoZilla is offline   Reply With Quote
Old 01-27-2021, 01:54 PM   #614
roll_the_dice
Thanks...it feels so good to be able to drive it again. So would you cut off the existing studs and weld new ones on the faceplate using threaded rod of the right thread pattern? I like the idea of a lock on one of them...thanks, good thinking!
Old 01-27-2021, 02:12 PM   #615
roll_the_dice
OK so I started painting my new valve covers...here are some of the progression shots of the process.
I took the raw aluminum and sanded it so it wasn't as rough as the original sand casting. Not enough to polish it...but enough..went from 40 grit paper to 220 on all surfaces. You can see some "rough" spots around the Corvette script and between the fins where I did not do any sanding of the original casting. Wasn't worth the effort IMO. I then painted green (3 coats) to match the bits under my hood. I let that dry overnight. I scuffed that up a little on top so that black paint would adhere better. I then masked off what I wanted black....then shot the black. Once the last coat of black was laid out I pulled the tape off so there were no hard lines. The next day, I sanded off the raised fins and script with 220 grit on top. Where the black paint rolled to the side and faded out I used lacquer thinner and a micro dabber to get the black paint off the fins and shape the black where it stopped. I then hand sanded any bits that the lacquer thinner wouldn't get. If I sanded too much I touched up with a micro dabber. I still need to clear coat it all tomorrow...and polish the top fins and script... I love the result.
Old 01-27-2021, 11:41 PM   #616
350TacoZilla
Basically the way I would tackle it would be to cut off and grind down the existing studs then drill the holes for new and use G8 bolts in correct thread pattern, push them through the holes then weld them on the back side. For the lock you could use a matching wheel lock to the truck if you can find a company that will send 5 matching ones if you want it cleaner looking than the more commercial style lock I mentioned before lol.
Old 01-27-2021, 11:50 PM   #617
cwcarpenter98
The valve covers look great!
Christian Carpenter
Old 01-28-2021, 10:40 AM   #618
roll_the_dice
Exactly how I was thinking--cutting off and grinding them down and then drilling and using a bolt of the appropriate size from the backside welded in. Thanks!
Thank you sir...since the truck is drivable, now the fun part of making some pieces nicer looking can begin.
Old 01-29-2021, 12:28 PM   #619
88Stanger
88Stanger's Avatar
Beautiful work! Just awesome work so far. Love the valve covers... how many sets of like those i have had over time..... lol
John 3:16 - Saved me... God Bless
88Stanger is offline   Reply With Quote
Old 01-31-2021, 01:17 PM   #620
straight6chevyguy
straight6chevyguy's Avatar
Glad to see the truck back together and driving.
Those valve covers came out nice too.
1965 chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601
1976 chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037
1998 chevy c1500 4.3L 5speed (My current driver)
2002 Chevy s10 4.3L auto 4x4
1971 mercury monterey wagon 400 auto
To many projects!
straight6chevyguy is offline   Reply With Quote
Old 02-04-2021, 12:05 PM   #621
SCOTI
SCOTI's Avatar
Valve covers look good. The effort shows.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-04-2021, 12:18 PM   #622
roll_the_dice
Thanks guys...I appreciate the kind words. I clear coated the valve covers this week. Just waiting on the clear to cure then I will spot wet sand and polish them. A little bit of trash in a place or two...but I do love them. Hope to get them installed this weekend.
Old 02-20-2021, 07:45 PM   #623
roll_the_dice
Haven't been doing a whole lot on the truck other than driving it and trying to fine tune the Fitech. I want to paint the rally wheels soon also. However, today I finally swapped out my valve covers. I love the new ones...dresses up the engine bay so well. Here are a few pictures...a before and after.
Old 02-20-2021, 09:08 PM   #624
Duncan K
Those covers look really good in there. Gorgeous engine bay!
66 GMC 910
My Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=754257
Duncan K is offline   Reply With Quote
Old 02-21-2021, 12:05 AM   #625
66C10LB
Beautiful engine bay!
66C10LB is offline   Reply With Quote
