07-13-2020, 08:51 PM | #1 |
suspension
What is this suspension under my 87 k10 short box, it looks way to beefy for a k10.
Is it k20 ???? |
07-13-2020, 09:14 PM | #2 |
Re: suspension
I've got a 87 v20(same as k20) pickup with stock suspension. The front leafs are nearly flat, not arched like those. It only has two or three leafs in the front, not that stack.
I don't think you can go much by the number of leaves in determining the weight capacity. Different aftermarket companies would build them with different spring rates per leaf, different widths, thicknesses, quantities, etc.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
07-19-2020, 06:55 PM | #3 |
Re: suspension
Aftermarket 4" lift spring with raised steering arm in the front and 4" lift blocks in the rear.
07-19-2020, 08:51 PM | #4 | |
Re: suspension
what color spring eye bushings up front ? this tends to help id the brand . or is there any stickers or inked on part no's ?
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
07-20-2020, 07:33 AM | #5 | |
Re: suspension
Thanks for the help , now I know what's under it. |
07-20-2020, 07:40 AM | #6 |
Re: suspension
they were prob red before fade out .
could be a few brands of lift that run that color . makes it a bit harder to narrow it down . but if i had to guess off the pack style and leaf count up front and popular for there CHEEP price point rough country . i dont run them tho as there is a reason there so cheep in price . the ride is real stiff over other brands .
07-22-2020, 07:16 AM | #7 |
Re: suspension
I replaced them with energy susp.
07-28-2020, 11:11 PM | #8 |
Re: suspension
Good eye on that add a leaf!
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
07-29-2020, 07:24 AM | #9 |
Re: suspension
Another question on the steering , it turns nice and sharp the one way and not near as sharp the other way , couldn't of been like that from original ???
07-29-2020, 09:11 AM | #10 |
Re: suspension
your reaching the limits of push/pull stock steering at this lift height and still being effective both ways .
most guys now swap in crossover steering kit and it makes it so much better .
07-29-2020, 04:28 PM | #11 |
Re: suspension
Looks more like a 6'' lift kit---and the steering shock is mounted wrong on the housing
07-29-2020, 09:11 PM | #12 |
Re: suspension
07-30-2020, 12:32 AM | #13 |
Re: suspension
For a quick and easy fix swap the pitman arm on steering box for a 2" drop version and you will be back in the ballpark. It will get the draglink close to level. Might want to think about adding swaybar drop brackets or better yet the ORD swaybar disconnect with shackles. Will help with spring movement.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
07-30-2020, 09:56 AM | #14 | |
Re: suspension
and more info on 6" = rear block at 3.5"-4" and a ADD-A-LEAF = 6"
07-30-2020, 10:02 AM | #15 |
Re: suspension
07-30-2020, 08:40 PM | #16 |
Re: suspension
07-30-2020, 08:48 PM | #17 |
Re: suspension
Here's a pic of the steering pitman arm , I don't know if it's stock or not ????
07-30-2020, 09:02 PM | #18 |
All about them K’s
Re: suspension
Yea that looks stock to me, personally I’m a bigger fan of the raised steering arm on the axle but that’s just my opinion.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
07-30-2020, 09:14 PM | #19 | |
Re: suspension
@4u2nv Pitman arm on steering box is stock. Change it to a 2" drop. As I mentioned the steering arm has already been changed.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 Last edited by 57taskforce; 07-30-2020 at 09:56 PM. |
07-30-2020, 09:24 PM | #20 |
Re: suspension
and sway bar kit from one of these guys to avoid the drop brackets .
yes stock box / pitman arm . needs a drop arm now i see that angle . steering shock is on the bottom of the axle bracket . needs to set on top of the bracket . pull bolt and move on top and reinstall bolt and good to go . disconect kit https://www.offroaddesign.com/swayba...gm-trucks.html but side note our square truck this tall and spring packs like you have now the sway bar does almost nothing so lots of guys just remove them . the stock gm springs were real soft and these lift springs are stiffer and dont need it as much . but thats personal preference . that sway bar the way it is now is got the front end so bound up from pulling forward and then the shackles wana flex back its fighting its self . i run a k10 with 1ton axles and 6" lift / 3" body lift and 38x12.50x16.5 tsl swampers for years no sway bar and no problems . and if you dont have one up in there get one of these quick before the frame breaks . 73-80 frame https://www.offroaddesign.com/bolt-i...wd-trucks.html 81-87-91 frame https://www.offroaddesign.com/bolt-i...wd-trucks.html
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. Last edited by sweetk30; 07-30-2020 at 09:29 PM. |
07-30-2020, 09:39 PM | #21 |
Re: suspension
Thanks all , looks like I will be doing some changes.
By removing the front sway bar will that improve some ride quality ??? |
07-30-2020, 09:59 PM | #22 | |
All about them K’s
Re: suspension
07-30-2020, 11:28 PM | #23 | |
Re: suspension
think of it in its current setup its holding it in 1 place and not letting it flex .
07-31-2020, 02:25 AM | #24 |
Re: suspension
Good recommendations by 57taskforce and sweetk30. By to look of your front springs they are of the stiffer variety. I am installing crossover on my truck. It is nice but I do not think it is necessary without a flexy suspension. I will have a 4 link with coilovers. As far as the swaybar, removing it would help as much as adding the disconnect kit. Obviously removing it is cheaper than adding the disconnect kit. Removing it costs nothing but time. You can put it back in.
07-31-2020, 09:19 AM | #25 |
Re: suspension
The shock should be parallel like the drag link. Remove the shock from the axle housing mount and put it on top, 1 nut and lockwasher-- rotate the shock housing, tighten nut from bottom----will take about 4-5 minutes
