Old 04-27-2017, 08:20 PM   #1
Flmarine71
Flmarine71's Avatar
Replaced Distributor- Starter making grinding noise
1978 K5 with original 350. Replaced my distributor and did the engine bump quite a few times (a lot) to confirm TDC/compression stroke. Now starter is making loud grinding noise. I'm recharging battery just in case to try again. Starter looks like it could be original though. Should I just go ahead and replace it? Any suggestions would be appreciated. Thanks.
Flmarine71 is offline   Reply With Quote
Old 04-28-2017, 09:56 AM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: Replaced Distributor- Starter making grinding noise
Originally Posted by Flmarine71 View Post
... Should I just go ahead and replace it? Any suggestions would be appreciated. Thanks.
Starters are fairly cheap. My theory on this is if it's an old starter, replace the complete starter and solenoid -usually between $35 - $50.
In the past I have also replaced just the solenoid if I suspect it to be the problem and in other instances the starter gear (bendix) if the starter itself is in good shape.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 04-29-2017, 06:40 PM   #3
Flmarine71
Flmarine71's Avatar
Thanks 68- I replaced with a reman Napa starter today and no more grinding noise.
