08-01-2020, 02:19 PM | #426 |
Re: 1965 LWB Stepside Build
You gonna be riding real soon my friend.
Former Decorated Combat Marine...Semper Fi!! Instagram jorourke322 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=734699 2019 GMC AT4 |
08-02-2020, 08:16 PM | #427 |
Today was a good day! I got my "new" 64 GMC 1 ton delivered and my black walnut wood was delivered. My buddy John (Johns 66) milled and cut the wood for me and Steve (GMCNUT) delivered it along with the truck! It is weird seeing 2 60's trucks sitting in the driveway...Can't start working on this one until I finish the 65...
Can't wait to start finishing the wood. It's going to look killer! Last edited by roll_the_dice; 08-02-2020 at 10:56 PM. |
08-03-2020, 12:07 AM | #428 |
[QUOTE=roll_the_dice;8786097]Today was a good day! I got my "new" 64 GMC 1 ton delivered and my black walnut wood was delivered.
Trucks look great! But dang you are crazy! I don’t have enough time to work on 1 truck! Both projects look fun though. Keep it up! Posted via Mobile Device |
08-03-2020, 11:37 AM | #429 | |
All I need to do to get the 64 driving is change out the gas tank (which I have) and put a new master cylinder/bleed the brakes. |
08-03-2020, 03:49 PM | #430 |
Yepper...cant wait to see the bed all buttoned up!!!
08-11-2020, 12:47 PM | #431 |
Put my "new" radiator support on today that I got from John. Thanks John! My old one had some waviness in it (last picture) and had more rust holes than I liked. This one is so much better! I also drilled a 1/4" hole in for drainage in the area that usually rusts out on these. Hope it helps.
Going this afternoon to talk to a shop about exhaust and charging up the A/C. Hope to have the rest of the front end on this weekend. |
08-11-2020, 01:42 PM | #432 |
The "new" support looks so much better! Keep up the good work!
Christian Carpenter 1963 C10 - Frankentruck 283, 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
08-11-2020, 04:17 PM | #433 |
Thanks Christian...I appreciate it.
I stopped at O'reilly's today for a lower radiator hose. They let me go in the back and look at all the ones they had. I found one that I thought would work based on water pump location ...so I took a chance and bought it and came home and it fit perfectly without cutting to size at all! I am stoked about that! Now I just need to find my hose clamps. |
08-11-2020, 08:27 PM | #434 | |
08-12-2020, 02:55 PM | #435 |
Looking good!
And I like the new truck too! It would be hard for me to keep my attention on just the one truck lol.
1965 chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601 1976 chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037 1998 chevy c1500 4.3L 5speed (My current driver) 2002 Chevy s10 4.3L auto 4x4 1971 mercury monterey wagon 400 auto To many projects! |
08-12-2020, 03:09 PM | #436 | |
I can see the finish line on the white truck...that is my only focus right now. Edit: I forgot to say..when I do the orange truck, I want a flat bed and rails like yours! |
08-12-2020, 03:10 PM | #437 |
Got the drivers inner fender on today and mounted everything tight. So weird seeing it go back together...it's been so long I forgot what it looked like!
08-12-2020, 03:47 PM | #438 |
Hey! Slow down, you’re making me look bad!! Haha, I was the same way when I put the front end on. You forget how sexy these old trucks look!
63 C10 |
08-12-2020, 04:18 PM | #439 |
Looking great Andy...you will be rolling in no time at all!!!
08-12-2020, 04:55 PM | #440 | |
I need to clean up the grille support and clear coat it...maybe get it on this weekend or get the work done this weekend. Anyone know what size bolt is in the bottom of the fender well where it attaches to the cab? |
08-12-2020, 05:05 PM | #441 |
That lower rad hose is nice! Do you still have the part numbers for both upper and lower hoses? I want to get rid of the crappy looking flexible hoses that I have
08-12-2020, 05:17 PM | #442 | |
The top hose is the one that was on my truck when I bought it. I haven't replaced it yet, but it seems to be in good condition. I cut about 2" off on the engine side from original. I think it is a standard 1 1/2" C10 hose and cut to length. At least the shape looks that way to me. |
08-12-2020, 06:33 PM | #443 | |
With the fender on, it's starting to look like a truck again!!
08-12-2020, 09:21 PM | #444 |
Truck Yeah!!!!
08-15-2020, 02:51 PM | #445 |
Got the drivers fender on before the afternoon rain... after lunch/rain break, I am going to start cleaning the back of my grille support get it ready for POR 15...
08-15-2020, 04:20 PM | #446 |
Progress is looking good!
63 C10 |
08-15-2020, 06:38 PM | #447 |
Take it for a spin like that
08-15-2020, 08:06 PM | #448 |
Thanks...It is coming along now! I see the light at the end of the tunnel.
Funn you say that...I said to my wife...want to go for a ride in the truck?! If it had exhaust I would! I got the back of grille support cleaned up with a wire wheel...going to put some por 15 on it Monday. Then I will clear coat the front of the support and paint the part behind the grille black like original. I hope to get that grille on at some point this week...then the hood! |
08-15-2020, 08:07 PM | #449 |
Glad I had this emblem to remind me what truck I had. It has been so long I almost forgot!
08-16-2020, 05:54 PM | #450 |
Trying to keep from buying "new parts"...I am doing some cleaning up on the grille/grille support...decided to see if I could clean my headlight bezels...blasted them, then sanded with 220 and 320 grit paper...night and day difference. Going to clear coat them this week so they don't rust again...
One bezel done, one to go! |
