08-12-2020, 08:18 PM | #1 |
1963 Chevy C10, 1975 engine...perches
does anyone know of any aftermarket engine perches for the inline 250? I couldn't find any, PO had a make shift set up that wasn't good
Ich möchte vroom vroom |
08-12-2020, 09:54 PM | #2 |
60-66 Nut
Re: 1963 Chevy C10, 1975 engine...perches
Why not just use a set of factory engine mount bracket? The are all the same '63-'72 for the 230/250. The '63-'66 small block mounts are the same as well.
08-12-2020, 09:57 PM | #3 |
I was going to ask the same thing as CaptainFab
Christian Carpenter 1963 C10 - Frankentruck 283, 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
08-13-2020, 09:47 AM | #4 |
Here is some good info on perches...but it reiterates what CaptainFab said...
http://www.persh.org/Pickup/perches.htm |
08-13-2020, 02:26 PM | #5 |
I'm just glad to be here!
I might have a set of factory perches in my stash if you can't find any local to you.
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
