Old 07-31-2020, 09:42 PM   #1
truckster
truckster's Avatar
L31 Vortec Ports
It's been a while since I tore this engine down, and I can't remember what went here. These look like they're perhaps ports in the oil galley, but I'm not sure. If so, what size plug do they take? I tried 1/4 NPT and it's too large, but they're much larger than 1/8th.
Thanks.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 07-31-2020, 10:50 PM   #2
clinebarger
Re: L31 Vortec Ports
Those are clutch Z-Bar Pivot mounting holes, No need to plug them. You have the one oil pressure port plugged above the oil filter.
clinebarger is offline   Reply With Quote
Old 07-31-2020, 10:59 PM   #3
Captainfab
60-66 Nut
The threads should be 1/2"-13 bolt threads for the ballstud for the clutch bellcrank. Which hole to use depends on the chassis being installed into.
Old 07-31-2020, 11:28 PM   #4
truckster
truckster's Avatar
Makes sense - the block came out of a manual transmission truck. I have a TH350, so I'll just leave them alone.
Old 08-02-2020, 05:41 PM   #5
toolboxchev
On another note it looks as if you have your cooling system grounded? Inquiring minds want to know.
toolboxchev is offline   Reply With Quote
Old 08-02-2020, 07:20 PM   #6
PGSigns
PGSigns's Avatar
Looks like a block heater.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 08-02-2020, 08:34 PM   #7
truckster
truckster's Avatar
It's a block heater. I'm getting old and I hate being cold...
Old 08-04-2020, 10:01 AM   #8
toolboxchev
Smart
