Old 08-07-2020, 10:10 AM   #1
The Rocknrod
Moderator
The Rocknrod's Avatar
Vortec Coolant Bypass
I'm using the following heater valve on my two hoses that run from and to the heater/engine - https://www.oldairproducts.com/produ...ve-kit-50-1555
Say's "Special design diverts coolant directly to the engine, away from heater core, when in the off position to reduce excess heat inside the vehicle"
In my minds eye that would mean I shouldn't need a bypass hose on my Vortec head style engine? What do you think?
Old 08-07-2020, 10:45 AM   #2
PGSigns
PGSigns's Avatar
Re: Vortec Coolant Bypass
Not sure on the bypass, I don't run one. Over 60,000 miles with out an issue.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 08-07-2020, 11:00 AM   #3
The Rocknrod
Moderator
Jimmy
Anything special on your thermostat? Holes or type?
Ya, I'll probably be okay.
Old 08-07-2020, 01:18 PM   #4
mongocanfly
Post Whore
mongocanfly's Avatar
Not sure on the vortec but I'm using one on my LS....which I've been told needs the bypass
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 08-07-2020, 03:49 PM   #5
sweetk30
sweetk30's Avatar
my new gm L31 i installed was burping and girggling until i did the little bypass hose from the water pump to intake like a BBC engine has from the factory .
i read a lot and asked a lot on this and it seems 50/50 mix of problems or no problems so try it and you will know . mine would pass gas in to the overflow bottle and then when the blower fan was on you would smell coolant like a bad heater core leaking . also if the vehicle is quiet i was hearing the rad cap letting it past .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 08-08-2020, 01:34 AM   #6
toolboxchev
Vortec block or no? I am told the some of the blocks have the bypass in them, in turn which does not require the bypass from back of intake manifold.
This is a roller motor no doubt.
Here is a pic
toolboxchev is offline   Reply With Quote
Old 08-08-2020, 01:37 AM   #7
toolboxchev
I do like what your thinking. Making it comfortable in the Summer. I know that stupid little heater core will take 10-15 degrees off the engine in summer.
Old 08-08-2020, 10:32 AM   #8
sweetk30
sweetk30's Avatar
Here is a pic
not the back of the intake . its the front of the intake . the back pass side was just the heater core feed in later years to simplify stuff.
Old 08-08-2020, 11:12 AM   #9
tdangle
tdangle's Avatar
I believe it's the vortec heads that don't have the bypass not the block. Could be wrong.
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 08-09-2020, 10:24 PM   #10
Captainfab
60-66 Nut
That is correct. Every '95-'02 block I have had, still has the bypass passage as in the pic in toolboxchev's post. It is the Vortec heads that do not have the matching hole drilled in the deck surface. This can be easily drilled when building an engine.
Old 08-09-2020, 11:18 PM   #11
gmc684x4
I will have to look and drill my two sets of vortec heads if they dont have this hole
In the slow process of pulling one now with my broken leg takes me longer to do these days
gmc684x4 is offline   Reply With Quote
Old 08-10-2020, 09:53 PM   #12
Captainfab
60-66 Nut
None of the Vortec heads have that hole drilled in them. That is why the L30 and L31 use an external bypass.
Old 08-11-2020, 03:10 AM   #13
gmc684x4
The one thing i should ask do you need to drill out front and back of both heads ?
Old 08-11-2020, 03:15 PM   #14
garyd1961
It's a lot easier to add a bypass than it is to drill heads.
garyd1961 is offline   Reply With Quote
Old 08-11-2020, 06:41 PM   #15
sweetk30
sweetk30's Avatar
x2
Old 08-11-2020, 09:45 PM   #16
Captainfab
60-66 Nut
The bypass is only on the passenger side at the front. If your engine is already together, no need to pull the head. Just plumb in an external bypass as sweeetK30 did.
Old 08-11-2020, 10:06 PM   #17
truckster
truckster's Avatar
Here's mine. The hose is Gates #12044, cut to fit.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 09-04-2020, 12:14 AM   #18
gmc684x4
I see what you mean easier to do the bypass then drill the heads
I did not realize you had to drill the passages in the heads at an angle
