10-25-2020, 10:55 PM | #2 |
Re: Anyone ever see this fault code? It sounds serious!
Not serious at all....
*Is the alternator charging? *What is the battery voltage with the engine running? *Are you running the factory 2005 alternator? *Is the Regulator plugged in? 2005 1500's was the first year for the alternator control module, I generally segment swap these PCM's & run a 2500/3500 or 2004 & earlier 1500 alternator. |
