Old 04-09-2021, 07:29 PM   #1
pjmoreland
pjmoreland's Avatar
Bed Wood Painting Fiasco
I purchased a pine wood set from Mar-K a few months ago for my stepside bed. My plan was to follow their guidance on painting it first with POR-15 and then with exterior enamel. The coats of POR-15 went on fine, although the surface finish ended up quite rough, so I sanded it with 220 grit prior to applying the enamel. The guidance from Mar-K didn't specify latex or oil enamel, so I purchased a can of latex. I got insecure at the last minute due to the fact that POR-15 is cleaned up with lacquer thinner, so I purchased some oil base paint instead.
This was a big mistake!
I applied the first coat of oil based enamel during the evening, so the lighting wasn't too great. I guess I didn't do the best job of cleaning up the boards after sanding the POR-15 (blew them off with an air compressor) because there were hundreds of little bumpy specks in the paint. Also, the first coat of enamel took a full week to get to the point where it was no longer tacky to the touch.
At that point I sanded the paint down to eliminate the bumps and applied a second coat of paint. Now that we are getting into spring, there are lots of bugs out, especially in the evening. I made the mistake of leaving my garage door open, and a few dozen bugs landed in the paint. Thankfully, this second coat was dry enough by the next day that I was able to sand the bugs out and apply a third coat. Within about 15 minutes of applying the third coat, ridges started forming in the underlying layers of paint due to being reactivated by the fresh paint! I called a buddy of mine who owns a painting company, and he suspected this was a result of cleaning the surface of the boards with lacquer thinner prior to applying the paint. Based on this input, I waited another 24 hours, sanded the boards again, and applied a fourth coat without cleaning with lacquer thinner first. The same thing happened again. More ridges!
At this point I was so frustrated that I placed an order for another set of wood and was planning on having my buddy spray them with whatever kind of paint he thought was best. I canceled the order a few days later after thinking about how much money would be down the drain.
I did some reading online and found a website that said oil paint can take up to 30 days to cure completely. I decided to leave the boards in an unused room inside the house for 30 days and then try again. Yesterday was the 30 day mark, so I sanded and repainted one board, and it did not wrinkle up! I sanded and painted the rest of the boards, and only one spot about the size of a quarter ended up wrinkling. I can live with that at this point. This isn't a show truck, and I plan on using the bed for light hauling, but I want it to look decent. I think I will achieve that goal.
I should have used latex. After digging around in the Mar-K document archive, I did find one document that says they used latex. Oh, and by the way, the POR-15 documentation says any type of paint can be applied over it.
I've included an image from the 1968 sales brochure. That's the look I'm going for.
pjmoreland is offline   Reply With Quote
Old 04-09-2021, 07:54 PM   #2
dmjlambert
dmjlambert's Avatar
Re: Bed Wood Painting Fiasco
I'm glad it worked out with your 30 day wait. I think that it came out nice and that quarter size defective area probably wouldn't bother me either on a truck I planned to use. You have posted some good information, I think others will benefit from your experience with this.
Old 04-09-2021, 08:04 PM   #3
pjmoreland
pjmoreland's Avatar
Thanks. Now I just need to fight the urge to touch up that one spot. Any messing with it would probably make it stand out more than it already does.
Old 04-09-2021, 08:16 PM   #4
dmjlambert
dmjlambert's Avatar
Yes, resist the urge! This can be your homage to the Persian rug, perfectly imperfect and precisely imprecise.
Old 04-09-2021, 08:23 PM   #5
pjmoreland
pjmoreland's Avatar
I like it 😄
Old 04-12-2021, 09:50 PM   #6
Peanut74
pjoreland, I feel your pain. I basically did the same thing you did with painting my truck. Go to cut and buff and sand though and have to touch up the paint. Then the patch paint runs and its back on the merry go round again.
Resist the urge to try and make it perfect. 90% of the people will never notice it.
1967 C10 "Snowball" (Currently in a million pieces down from a bazillion)
1989 Toyota DLX pickup "The Hulk"
2012 Jeep JKU "Crush"
1976 Chevy short bed with a 327 and 3 on the tree (Sold it to buy the Blazer)
1971 Chevy Blazer (Sold it)
Peanut74 is offline   Reply With Quote
Old 04-12-2021, 09:52 PM   #7
pjmoreland
pjmoreland's Avatar
I'm not brave enough to try to paint an entire truck. I have a lot of respect for anyone who takes on that project. I will fight the urge to touch up the paint!
Old 04-13-2021, 07:19 PM   #8
slikside
slikside's Avatar
Just make that the first spot you "bugger up" when using it for light hauling!
I think it's gonna look great!
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, all stock, Survivor.
slikside is offline   Reply With Quote
Old 04-13-2021, 09:53 PM   #9
dagnabbitt
dagnabbitt's Avatar
Looks awesome in my opinion. I didn't know that you could POR15 wood. Did I read that correctly?
When it comes to touchups: I have learned to sleep on it, always.
Again, I really like the result you got, I am sure they came with a blemish or two from the factory also!
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 04-14-2021, 01:40 AM   #10
pjmoreland
pjmoreland's Avatar
Yep, Mar-K recommends two coats of POR-15 followed by three coats of high quality exterior latex paint. POR-15 has poor UV resistance, so the latex protects the POR-15 from the sun.
Here's the completed bed floor.
Old 04-14-2021, 02:11 AM   #11
notsolo
notsolo's Avatar
Wow, that turned out Great.
notsolo is offline   Reply With Quote
Old 04-14-2021, 02:25 AM   #12
pjmoreland
pjmoreland's Avatar
Thanks! It is probably a little too nice because now I'm going to be trying not to scratch it
Old 04-14-2021, 06:39 AM   #13
notsolo
notsolo's Avatar
The finish is perfect, I don't know if you can get results like that with latex?
Old 04-14-2021, 08:10 AM   #14
Boog
laying low
Boog's Avatar
That turned out great. Thanks for answering the question about using por15 to seal wood. I also wondered if bed liner could be used directly on wood for lasting protection.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 04-14-2021, 08:46 AM   #15
67C10Step
67C10Step's Avatar
That looks so good you now have me considering painting my bed wood instead of staining. My truck may never look even remotely as good as yours and will certainly never be a show truck.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2020 Toyota CH-R
2020 Acura MDX
67C10Step is offline   Reply With Quote
Old 04-14-2021, 08:55 AM   #16
georgieb51
georgieb51's Avatar
Just wondering if you sealed all sides of the boards. If not moisture can enter from below and contribute to cupping in the future. I am glad to see folks interested in painting their truck beds. I am currently in the process of sealing and priming my oak boards for my stepside. Glad to see another use for POR. I am using different materials that I have learned about when restoring wood boats, but basically that first sealing coat is critical.
1972 Chevy Custom Deluxe Highlander, owned 34 years.
1970 GMC Sierra Grande 2500, unrestored, original.
1970 Chevy K10 Short Wide-bed, working on restoration..
1967 Chevy K10 Short Stepside, unrestored original.
1969 GMC CST (Longhorn) 396, buckets, unrestored.
1995 GMC K2500, 65,000 miles, 454.
georgieb51 is offline   Reply With Quote
Old 04-14-2021, 10:39 AM   #17
pjmoreland
pjmoreland's Avatar
I painted all sides of the boards. Are you referring to some other type of product besides paint for sealing?
Old 04-14-2021, 10:41 AM   #18
pjmoreland
pjmoreland's Avatar
I absolutely love the patina your truck has. There's no duplicating that.
Old 04-14-2021, 10:45 AM   #19
pjmoreland
pjmoreland's Avatar
Seems like bed liner would work well since so many people use it in their metal beds with lasting results. I was somewhat blindly following the recommendations from Mar-K. Most of their long-term tests centered around clear finishes, so they didn't have much of a selection on painting options. One of their earlier paint tests didn't use POR-15, and it failed. The POR-15 combination they tested held up really well long term.
Old 04-14-2021, 10:53 AM   #20
pjmoreland
pjmoreland's Avatar
This is what the wood looked like in my old '67 after 12 years of being parked mostly outside in Colorado. It was finished only with linseed oil. I reapplied the oil a few times over the first couple of years, but then I totally neglected the wood after that. I'm hoping the paint will do a better job of preserving the wood without requiring yearly maintenance.
Old 04-14-2021, 11:01 AM   #21
pjmoreland
pjmoreland's Avatar
The wood Mar-K painted with latex looks pretty good.
https://www.mar-k.com/PDFs/Instructi...testupdate.pdf
Old 04-14-2021, 11:32 AM   #22
dagnabbitt
dagnabbitt's Avatar
I have a friend who bedlined his metal strips as well as the interior of the box sides and tailgate: but he did what you did with the wood, just painted it black. It looks really sharp.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 04-14-2021, 12:07 PM   #23
Boog
laying low
Boog's Avatar
Some years ago while purchasing new flat bed trailers with wood floors the salesman recommended we use Thompson's deck and wood sealer to prolong the wood. The Apitong wood holds up pretty good, at least here in the south. Anything to seal and keep the moisture out will prolong the wood and increase a unit's trade in value.
Boog
primer is finer
Old 04-14-2021, 10:46 PM   #24
57larry
does anybody just use stain for their bedwood?
57larry is offline   Reply With Quote
Old 04-15-2021, 12:01 AM   #25
Grumpy old man
Grumpy old man's Avatar
https://www.youtube.com/watch?v=uUixj8egCNM
https://www.youtube.com/watch?v=V2dMRRU0OEE
