Old 12-14-2015, 06:52 PM   #1
64chevtruck
76 GMC CCLB Dually, The Blue Ox
Hi guys, Ive been wanting a huge long dually truck to lower since I first saw one, I finally picked one up in trade last week that a guy put a large notch in the back and gave up on, Nothing was done up front but the guy cut the springs in half.......
I have been searching build threads for info...
I have one major question for the masses...
Do people pancake the crossmembers on their dually trucks like Ive done in the past on my half tons>? Please direct me to a thread if anyone knows of one.
Anyway I took the CM out. Patient is prepped and ready for surgery so I hope to hear back soon.
Take care
64 C10 Fleetside LB 4 Sp/292 Build http://67-72chevytrucks.com/vboard/s...d.php?t=602438
70 GMC 1500 Fleetside LB 3OT/350 Build http://67-72chevytrucks.com/vboard/s...83#post6767983
76 GMC CCLB Dually Build http://67-72chevytrucks.com/vboard/s...d.php?t=691612
79 GMC 3500 Fleetside LB 454/400
90 Suburban Silverado 4x4 350/700R4
97 1500 Cheyenne Short Fleet 350/5sp
64chevtruck is offline   Reply With Quote
Old 12-14-2015, 08:03 PM   #2
DblTrbl
DblTrbl's Avatar
Re: 76 GMC CCLB Dually, The Blue Ox
There's no need to pancake or modify the crossmembers on these trucks unless you intend to bodydrop. The crossmember should be even with the bottom of your frame rails. I Z'd my frame up 4" only because I cut 4" off the bottom of my rails. Before the bodydrop, I planted the crossmember at the same time as the rails...
83 Crew Dually build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=686192
Instagram: lofab77
DblTrbl is offline   Reply With Quote
Old 12-15-2015, 12:28 AM   #3
64chevtruck
Hi, thank you for that info and your time. It is HIGHLY possible Ill end up trimming the bottom of the frame off like you did. I had no idea they hung down so low on these. I just need to figure out if I want to Z or pancake now, I like the way the Z moves the motor Steering/ front end and trans upward all at once.
and with a pancake I have to notch the frame and move the steering up,,,,, Cant decide right now,,,need more info and to sleep on it,
Thank you
Old 12-16-2015, 12:48 PM   #4
64chevtruck
Got the farmer mirrors off first thing,,,
Heres the truck sitting like I got it, flip kit in back, Springs removed in the front,
Demons ouuuut....
Old 01-17-2016, 11:09 PM   #5
64chevtruck
Howdy, So I picked up a 454 that was rebuilt and came with paperwork for 1500. Supposedly has around 60k on it. I also picked up a T400 and a T350 for 50 dollars.
Also picked up a set of Alcoas!!. >
Got started and marked out the CM and started cutting it.
Old 01-18-2016, 12:08 AM   #6
DblTrbl
DblTrbl's Avatar
Nice score on the Alcoas. The real deal in 16" is hard to find now since they apparently don't make that size anymore. If you're interested in swapping the lug covers over to spikes, iowa80.com has the correct size. Make sure that when you're mounting those wheels, you mount each with two acorn lugs to center the hub, then tighten up the flat lugs. If you don't, you'll feel it.
Instagram: lofab77
Old 01-18-2016, 12:31 PM   #7
64chevtruck
Howdy, thanks for the tip I will center with acorns for sure, I found the center caps mounted up by being pinched under a few of the lug nuts on these, this cant be the way they are supposed to be mounted though, I'm guessing these are the wrong center caps for these rims, they don't fit in the holes on the rims, anyone have info on these>?
I polished them up and they came out nice though.
also go the CM sectioned and back in the truck BUT..........
also found the drivers frame rail to be bent on the front horn by the steering box, you can see it in the top right pic, Ill have to figure out how to adjust this, May just weld a new horn on the front,
Old 01-18-2016, 01:38 PM   #8
DblTrbl
DblTrbl's Avatar
Yep, that's exactly how they work. I've had to explain it to tire shops for years...Alcoas are a different animal.
I've got the exact same wheels.
Instagram: lofab77
Old 01-19-2016, 12:25 AM   #9
TrailerTrash
TrailerTrash's Avatar
cant wait to see pics of this thing outside with those wheels
TrailerTrash is offline   Reply With Quote
Old 01-19-2016, 03:52 AM   #10
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
If you plan on body dropping the truck your still gonna have to Z it even though you pancaked the crossmember. It wont be as much of a Z now, but still gonna have to do it since the frame is so tall.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 01-19-2016, 06:17 AM   #11
64chevtruck
Thank you for the info Dt. Keep up the good work on your truck.
Me too Trailertrash!
Ruffrida. The plan at this time is to get the frame straight, all put together and drivable. My 64 is down to the frame and i need to focus on it.
Old 01-20-2016, 10:36 AM   #12
64chevtruck
My friend Barry came over and helped me put the motor and trans in, It was like throwing a hot dog down the hallway.
This was last week, Front end is on now and almost ready to start, More pics later today,
Take care,
Old 01-20-2016, 08:53 PM   #13
54earl
54earl's Avatar
I really like the color combo.
54earl is offline   Reply With Quote
Old 02-17-2016, 01:12 PM   #14
64chevtruck
So I got the motor and transmission in, core support painted and the rest of the stuff put on the front end, then I noticed the carrier bearing needed raised up alot, So I removed the crossmember it was mounted on and mounted it to the bottom of the cab with a few thick washers on top, It made my driveline pretty straight,
Then I ran the exhaust back to the rear end for now, I got it all tucked up tight above the frame line, I cut apart 2 exhaust systems that were fairly new, and pieced it together, Had a set of new Thrush mufflers I used at the back. Ill run em over the rear end later, Im just glad it goes back past the cab for now,
My steering column was trashed so I replaced the switch the rod moves, and got the starter hooked up right.
The key area is missing still but I can engage the starter with a nail in the switch instead of the rod for now,
Last thing last night I dumped some gas in the carb and fired it off, she popped but I still need to get it consistent fuel, That is todays mission, Hope to drive this very soon,
Have a good week.
Old 02-17-2016, 01:14 PM   #15
64chevtruck
this was exhausting,,,,,
Old 02-17-2016, 01:19 PM   #16
DblTrbl
DblTrbl's Avatar
Mounting the carrier bearing to floor with no additional support to the frame seems like you might be asking for trouble. There's a lot of forces at work there. Driveline vibration or any friction in that bearing will be disastrous. Just an observation...
Instagram: lofab77
Old 02-17-2016, 01:45 PM   #17
tinydb84
tinydb84's Avatar
x2
I'd build a crossmember to mount it. It looks like you can flip the bearing and make a pretty easy mount running across the frame.
David
Instagram: myfabguy
Old 02-18-2016, 12:04 AM   #18
75Dually
75Dually's Avatar
Can't wait to see more of this build! Please do me a favor before you drive that. You are going to need a support member for that carrier bearing. It will rip the floor right out from under you. Just not enough strength there to hold the large rotating forces on that drive shaft.
I've been around these trucks for a long time and just don't want you to tear anything up, or possibly get hurt.
My truck below for reference.
75Dually is offline   Reply With Quote
Old 02-18-2016, 12:55 PM   #19
64chevtruck
I agree the carrier could use a CM. Ill build one later on for it, Goal is to get this running and moving and out of the shop,
I have too many trucks at this point and need to focus on my 64.
Fixed the fuel problem, starts and runs now.
Need to mount the grill and back seat.
Have a good week.
Old 02-22-2016, 04:28 AM   #20
64chevtruck
I got it out of the shop and took it for a drive the other day,
I pulled a few hole shots by my house and the carrier bearing did fine, If it didnt blow out of there with my foot on the floor through 2 gears I figured an easy cruise would be ok so I went up to the store. Ill build a cm for it when I get back on this truck but its fine for now.
The trans wouldnt shift without running the rpms up pretty high for some reason, seemed like a large stall converter but I may not have everything hooked up right.
the rear tires rubbed but the rest worked out pretty good.
I packed a bike for the maiden voyage but ended up not needing it.
Seems more like a truck now than a dead horse.
All my focus at this time needs to go towards my 64 so Ill be on that build thread for a while.
Have a good week.
Old 02-22-2016, 04:42 AM   #21
64chevtruck
PS I looked at the title the other day and the truck is a 73, Not a 76 as I was told.
Old 02-22-2016, 08:39 AM   #22
ruffrida2005
Truck looks really good.
Paul
Old 02-23-2016, 12:31 AM   #23
TrailerTrash
Thumbs up Re: 76 GMC CCLB Dually, The Blue Ox
nice to hear its up and driving
Old 02-23-2016, 10:30 AM   #24
LT7A
That cracked me up. My "trial runs" are always in a circle near my house so I can get home on foot if need be. I've had to do the walk once. Maybe I should air up my tires and throw the bike in.
Cool truck. I like the colors, as a child I rode many miles right/middle seat in our Suburban with those paint colors. Howdy from a fellow Washingtonian.
Old 02-25-2016, 12:45 PM   #25
64chevtruck
So I finished ironing out some wiring issues, found some air leaks and added an angle iron crossmember back near the carrier bearing to hold the bottom of the frame rails together, I bolted it in so I can remove it later. Thanks for the feedback guys.
