Old 07-12-2008, 01:28 AM   #1
ERASER5
ERASER5's Avatar
Variable Ratio Power Steering
Does anyone know what year they started making the variable ratio power steering box for trucks, burbs, or blazers?
I am planning to go junk.. uhh salvage yard shopping tomorrow or Monday and I need to know what to look for.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 07-12-2008, 10:10 AM   #2
raggedjim
raggedjim's Avatar
Re: Variable Ratio Power Steering
Try this link, Rg
http://67-72chevytrucks.com/vboard/s...power+steering
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
raggedjim is offline   Reply With Quote
Old 07-12-2008, 10:28 AM   #3
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Read the link...so it might be the spring in the steering pump valve. How about quick ratio steering? I heard you could modify or retrofit with a JY quick ratio steering box...anyone done that?
I found a link to a company in AZ that will do yours for $170 but I recall Bob Moore (RIP) talking about buying auto parts store components (Camaro?) and rebuilding them.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 07-12-2008, 10:37 AM   #4
raggedjim
raggedjim's Avatar
I read it as the spring may affect "roadfeel" or the rate of assist. The 73-82 variable ratio box will give a quicker ratio than the original 68-72 box.
Sounds like the 73-75 boxes MAY use the same hoses as our trucks, but I do not know for sure...
Rg
Roger
'70 GMC Jimmy 2wd
Old 07-12-2008, 11:53 AM   #5
Indyuke
I used one out of a 1977 chevy truck. Bolted right in. The only reason I chose that year was because that was the best looking one at the junk yard.
Indyuke is offline   Reply With Quote
Old 07-12-2008, 11:58 AM   #6
caminokid
Chevy nut
caminokid's Avatar
I used one out of my old 87...I used the pump too. No problem with hoses then.
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II
"Remember kids there is NO replacement for displacement!"
caminokid is offline   Reply With Quote
Old 07-12-2008, 02:13 PM   #7
ERASER5
ERASER5's Avatar
Thanks for the help. So it seem that 73 & up is the answer.
I picked up Petersen's 4Wheel & Off-Road September issue. They have power steering/ram assist/hydro brake assist article. Good info, but they did not give any build dates.
Each piece was rebuilt. For the steering box, they showed variable piston and the straight cut piston. Big difference! Also, according to the article, the "road feel" is determined by the "torsion bar" shaft. This bar is the coupler from the steering wheel to the sector shaft. Apparently there are many different spring rates.
'70 GMC C1500 LWB
Posi 6 Lug Dana 60
Old 07-12-2008, 06:26 PM   #8
Mondo
Mondo's Avatar
I bought a quick ratio box for my 67. It works great for around town but going over 65 can be a little sketchy the first time as it's too sensitive ( I don't plan on any trips with gas prices as they are).
When everything is else is done I may get around to putting a variable rate one in.
Mondo is offline   Reply With Quote
