Old 01-07-2015, 09:29 PM   #126
Free Candy Inside
Re: Free Candy Inside: 63 Long Panel Build
Got a snow day today (teacher perks) so I headed out to the garage. Started working on mounting the body. Made an outboard mount
Free Candy Inside is offline   Reply With Quote
Old 01-07-2015, 09:30 PM   #127
Free Candy Inside
Got it mounted up
Old 01-07-2015, 09:32 PM   #128
Free Candy Inside
Then I started working on mounting a tank. Picture looks off, but everything is straight and level. Lol
Old 01-08-2015, 07:01 PM   #129
Mjminino
How come my teachers couldn't have been this cool?! What grade do you teach? Thermal Dynamics plasma cutter ain't no chump change. Maybe I need to do a career change!!!!!
Mjminino is offline   Reply With Quote
Old 01-08-2015, 10:00 PM   #130
Free Candy Inside
Haha. I teach high school health and phys Ed. This is my 5th year teaching. I actually got the plasma cutter really cheap. Like $200ish chea (I got it in a package deal with the welder I got off craigslist). Problem is the guy didn't have 220 at his place so I couldn't test either one. Took my chances. Welder works great. Plasma won't stay lit/cut. It just sparks the whole time. I changed the consumables but it didn't make a bit of difference. I took it to a buddy's house thinking maybe it was a power/air pressure/moisture in the line but it did the exact same thing at his place. A buddy took it to his work hoping to fix it.
Old 01-08-2015, 10:05 PM   #131
Free Candy Inside
Got another snow/too cold day. Got the tank mount finished. Also got the other side outboard mount started before I ran out of mig wire. Cleaned up the garage.
Old 01-10-2015, 02:23 PM   #132
65sub
65sub's Avatar
Cool build so far. I am curious about your gas tank. On a SWB suburban the filler is behind the rear wheel. Is your tank between the frame rails or outside? Do you have pictures?
Dale
My suburban's Twisted Little Sister
http://67-72chevytrucks.com/vboard/s...d.php?t=655167
65sub is offline   Reply With Quote
Old 01-10-2015, 05:55 PM   #133
Free Candy Inside
On this one (c20 or 30) the gas tank was mounted right behind the drivers seat outside the rail. I decided to leave it in the same spot but made/making a custom stainless tank.
Old 01-10-2015, 06:02 PM   #134
Free Candy Inside
Here's a pic of the custom tank that's going in it. The fatter end goes toward the drivers seat. The skinnier end is notched to go around my 4 link. Figure it's going to be roughly 15gallons.
Old 01-10-2015, 06:05 PM   #135
Free Candy Inside
Here's another pic. Baffles will be inside. I still need to figure out how I'm going to mount it, filler neck and securing the pump. I bought a piece of stainless at my local scrap yard for $40. Made a template and then went to a local shop that sheared it and bent it up for me for $40. Custom stainless tank for $80 thus far.
Old 01-10-2015, 09:30 PM   #136
Mjminino
I pmed you
Old 01-11-2015, 03:33 PM   #137
Free Candy Inside
I just set the bottom and side piece of the gas tank in the truck so you can see how I made it to go around the 4 link set up. Not sure if this helps you any.
Old 01-11-2015, 06:58 PM   #138
65sub
65sub's Avatar
Nice work on the new tank. Thanks for the pics. For the fuel pump have you looked at the Aeromotive Phantom in tank pump. Installation looks relatively easy.
Dale
Old 01-11-2015, 08:57 PM   #139
Free Candy Inside
I haven't, but I will now!
Old 01-12-2015, 08:06 PM   #140
Free Candy Inside
Got another snow day today lol. Got out to the garage and got my transmission crossmember done. I had one in previously but the angle was off and I had no way of running exhaust.
Old 01-12-2015, 08:09 PM   #141
Free Candy Inside
Because I wanted it as low as possible I decied to use a couple 1/2 inch thick energy suspension body bushings to dampen it to the mount. Here's it installed.
Old 01-12-2015, 08:13 PM   #142
Free Candy Inside
And it looks like I will now have plenty of room for exhaust now. I used some 2" pvc to mock that up. Lol
Old 01-12-2015, 08:59 PM   #143
Modges'66
Modges'66's Avatar
Location: Grand Rapids, Michigan, otherwise known as Beer City U.S.A.
Looks like that will work!
Nice!
Modges'66 is offline   Reply With Quote
Old 01-13-2015, 06:34 PM   #144
Free Candy Inside
When grinders attach! Was prepping some metal I couldn't clamp and it bit me. Looks worse than it is. Rinsed it off, a few bandaids and back to work. And yes, I had gloves on when this happened
Old 01-13-2015, 07:36 PM   #145
Ouch. Been there, done that..more than once too. Glad it wasn't too bad.
Old 01-13-2015, 07:44 PM   #146
uber cool
Now that got my attention
my rides
59 GMC Apache fleetside http://67-72chevytrucks.com/vboard/s...d.php?t=684337
68 VW Westy camper
uber cool is offline   Reply With Quote
Old 01-13-2015, 08:35 PM   #147
Free Candy Inside
Man look at that thing.. Its practically in a 4x4 stance. See how far my front bumper was to the ground? Glad I got it sorted out! lol
Old 01-14-2015, 10:55 PM   #148
Free Candy Inside
Today I bought a bunch of wire, some relays, and some odds and ends to try to get the air ride done. I messed around too much and only got the valves installed and the tank set in place. Hopefully tomorrow Ill get the compressors mounted up and do a little wiring. Going to be a simple set up. Accuair is cool and all but to me that's just way too much stuff to go wrong. Even if I was rich I'd still do a simple set up with just an few switches.
Old 01-15-2015, 11:16 PM   #149
Free Candy Inside
Tonight's progress: made some compressor mounts
Old 01-15-2015, 11:20 PM   #150
Free Candy Inside
And heres it together
