07-26-2020, 03:54 PM | #1 |
How to Measure Double D Steering Shaft
Can someone please confirm how to measure Double D hollow steering shaft. The widest dimension is 1" and narrower dimension is 0.86", so I am assuming that I have a 1" Double D hollow steering shaft which I need to make longer so I should order Borgeson 409536 http://www.borgeson.com/xcart/produc...7&cat=4&page=1
Thanks. Wade
53 Chevy 3100, SBC 355, 700R4, S10 frame, Ford 8.8 rear with 4.11 gears, front disc & rear drum brakes |
07-26-2020, 05:09 PM | #2 |
Re: How to Measure Double D Steering Shaft
Commonly the 3/4in DD is the solid shaft...the 1in DD is the hollow part that slides over the 3/4in DD
07-26-2020, 06:00 PM | #3 | |
HOWEVER you will need a coupler at the column, and most guys put a u joint there because the likelihood that your steering column points directly at your steering box is very rare. so rather than ordering a 1" DD shaft and a 1"DD to 1"DD coupler/u joint at the column, save yourself a 1/4" in space to the drivers side exhaust manifold and buy a 1"DD to 3/4"DD coupler/u joint and use a 3/4 DD shaft. if you have a GM steering box you will need a 30 spline to 3/4" DD u joint and just a word of advice, dont put the 3/4" DD shaft inside your 1"DD steering column hollow shaft and bolt it down, use a coupler or u joint!
07-27-2020, 11:38 AM | #4 |
Thanks for the input guys and thanks for the additional info Joedoh. Greatly appreciated. Got the parts ordered this morning so my 53 Chevy project continues to inch ahead.
