Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 05-28-2020, 10:43 PM   #1
Greg63
Enjoy your truck
Greg63's Avatar
'63 tach issue
I just replaced the stock points distributor, including Accel Super Coil w/ ballast resistor, with and Edelbrock Max Fire distributor, coil, and wires. The 327 runs great with this system but I have noticed the tach, which is a stock Sun in-dash unit, is not showing the rpm's correctly now. It appears to be low by several hundred rpm's all through the range, including idle.
Any ideas what is causing this and what the remedy may be? Could it be the ballast resistor no longer involved in the system?
1 Corinthians 10:13
1963 Chevrolet 1/2 ton
2010 Camaro SS/RS
2014 Jeep Grand Cherokee
2016 Jeep Cherokee
Greg63 is offline   Reply With Quote
Old 06-01-2020, 02:44 PM   #2
Greg63
Enjoy your truck
Greg63's Avatar
Re: '63 tach issue
I just went out for another drive and noticed this - the engine runs great but the tach seems "lazy". The needle moves but not at the rate it should. I also observed that the needle "bounces" at 3000rpm (gets to 3000 and drops, then back up to 3000 - like a rev limiter) even as I know I am revving past that.
Any ideas anyone?
1 Corinthians 10:13
2010 Camaro SS/RS
2016 Jeep Cherokee
Old 06-01-2020, 02:58 PM   #3
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: '63 tach issue
Stock Tach with an HEI "type" distributor right?
Old 06-01-2020, 03:23 PM   #4
Greg63
Enjoy your truck
Greg63's Avatar
Re: '63 tach issue
That is correct.
1 Corinthians 10:13
2010 Camaro SS/RS
2016 Jeep Cherokee
Old 06-02-2020, 05:25 AM   #5
Greg63
Enjoy your truck
Greg63's Avatar
Re: '63 tach issue
Is there a solution that is known to correct this? Will a tach signal filter sort it out?
1 Corinthians 10:13
2010 Camaro SS/RS
2016 Jeep Cherokee
Old 06-02-2020, 07:29 AM   #6
The Rocknrod
Moderator
Re: '63 tach issue
Originally Posted by Greg63 View Post
... Will a tach signal filter sort it out?
That'd be my opinion.
Old 06-13-2020, 07:38 PM   #7
Greg63
Enjoy your truck
Greg63's Avatar
Re: '63 tach issue
Any other ideas, anyone?
I bought and installed a tach filter from Glowshift and it didnt work. In fact with it wired in according to the diagram they supplied my tach didnt work at all.
1 Corinthians 10:13
2010 Camaro SS/RS
2016 Jeep Cherokee
Old 06-22-2020, 08:55 PM   #8
Greg63
Enjoy your truck
Greg63's Avatar
Re: '63 tach issue
No other suggestions?
1 Corinthians 10:13
2010 Camaro SS/RS
2016 Jeep Cherokee
