Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 10-04-2014, 09:29 PM   #1
Pzary3233
68 C10 parking lights, turn signals, and brake lights do not work
Working on this old truck to get her road legal and am having a very hard time with the lights to get them working.
I have the color coded diagrams from elsewhere on the forum and have tried to trace as much wiring as I can.
I have replaced the light switch and have a turn signal switch on order.
I have zero parking lights front or rear, no turn signals front or rear, and no brake lights either. Also, the dash lights don't work. Fuses are good.
At the brake light switch there is no power from the white wire coming from the turn signal switch.
At the light switch (new replacement) there is no power from any wires except for the red and light blue (headlights) wires.
At the turn signal switch I do get power on the purple wire but that's all.
At this point I think I have narrowed it down to the turn signal switch but I am not confident of my diagnosis. Is there any way to trouble shoot the switch with an ohm meter?
Anything I am missing?
'55 3200 283 4 speed
'68 Pontiac Firebird Poncho powered with a 6 speed
Pzary3233 is offline   Reply With Quote
Old 10-05-2014, 01:28 PM   #2
_Ogre
_Ogre's Avatar
Re: 68 C10 parking lights, turn signals, and brake lights do not work
one thing nice about working on gm vehicles is the wire colors haven't change (much) over the years
there should be 3 hot wires into your turn switch, if you have hazard blinkers
white wire is hot from the brake switch, not from the turn switch. this should feed 12v+ to the switch when the brake is depressed.
purple is 12v+ to the turn signal switch through the turn blinker. if your switch, wire and lights are good you should have turn indicators
if your truck has hazard lights there will also be a brown 12v+ from the hazard blinker to the switch
parking lights and tail lights have no connection to turn/hazard lights other than the same fixture and dual element bulb.
red is power to your headlight switch, blue goes to the hi/lo beam switch and brown for parking/marker lights
pic from vettevet in this thread. also wiring diagram for headlights and turn
http://67-72chevytrucks.com/vboard/s...d.php?t=593546
shop air compressor timer
Old 10-06-2014, 11:30 AM   #3
Pzary3233
Light switch:
I do not have power coming off of the light switch to any other wire except for the Lt. Blue wire when the lights are on. In the parking light position no wires are hot other then the red feed wire. The Orange wire does not get power when the light is turned to the dome light position. The Dk Green wire for the dash lights also does not get power when the light switch is turned on (Either Parking Lights or Headlights). When the switch is off, what SHOULD be hot? the Red wire only? When the switch is turned all the way on the Brown, Dk Green, and Lt Blue wires should ALL be hot. This is a new light switch, that is acting the same as the old one. Did I get a bad switch?
Turn Signal Switch:
I was confused thinking that the parking lights also ran through the turn signal switch... Just the brake lights so that they can be interrupted for a turn signal. I only have power going to the switch on the purple wire. there is no other power going TO the switch.
Brake Light Switch:
So you're saying that the Orange wire feeds power to the brake light switch which then feeds power to the turn signal switch. This orange wire has no power. Fuse is good. It looks like this orange wire travels from the fuse block to the dome light connector where it splits then to the brake light switch.
Wiring:
My wiring from the junction block at the firewall to the front parking lights has checked out good. Same goes for the wiring to the rear of the truck, from the firewall back it is in good shape. Grounds, I have cleaned the ground connections and added ground straps from the bed to the frame, from the engine to the frame and from the frame to the body. The truck should be well grounded.
Old 10-06-2014, 06:01 PM   #4
_Ogre
_Ogre's Avatar
light switch: after studying the wire diagram....
i have a feeling that the orange wire may feed power to the head light switch for your parking lights so read/fix brake switch first
you say it is acting the same as the old switch the orange wire power may be the only problem with the old switch
turn switch: with power to the purple wire your turn indicator lights should work
your truck has that silly half round column connector unplug it and jumper the purple wire to:
lt blue will tell you the lf light/wire is good
dk blue will tell you the rf light/wire is good
yellow will tell you the lr light/wire is good
green will tell you the rr light/wire is good
all these lights should also flash because the purple wire is from the turn flasher
if all your lights work then your turn switch needs work
brake switch: according to the wiring diagram that vettevet posted (where the heck is vettevet?)
it looks like you have a separate fuse for brake/dome in the panel
i am not sure why the orange wire also goes to the headlight switch; this may be the power in to the switch for the parking lights
pull the fuse and check for power at the fuse panel then trace power out from there
if the fuse is good and you have no power then a connection or wire is bad
getting power to the orange wire may fix a plethora of your problem
Old 10-06-2014, 11:12 PM   #5
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Well You are doing a pretty good job on this one so I've been watching to see what happens after he gets the new turn signal switch. I quoted your post so I could confirm what you are thinking based on the diagram below.
This is the headlight and fuse panel diagram for his model, the one above is for the 67 and newer models.
Name:  1 HEADLIGHTSWITCH 2.1.jpg
The orange wire does indeed feed the headlight switch for the parking, dome, and dash lights.Look closely and you can see it comes from the fuse panel to the switch for parking and dome light. The lights on the left are the dash lights. They are powered by the green wire which runs back to the fuse panel and then to the dash lights. The orange wire tees with another orange wire that goes to the brake light switch. The dome light is turned on with the switch knob by grounding the black wire on the headlight switch. All these items are related to the orange wire that feeds the headlight switch.
you say it is acting the same as the old switch the orange wire power may be the only problem with the old switch. Looks like it
turn switch: with power to the purple wire your turn indicator lights should work.
Yes as long as the TS switch is good. Power on the purple wire with the key on and the switch in the up position the dark green wire should have power, down position the yellow wire should have power..Light blue and dark blue are for the front signals as stated below.
Name:  turn signal .jpg
Another method is to use a multimeter and check for continuity on the wires in the switch. This involves the column side of the harness where the above checks the truck side of the harness as per Ogre.
Multimeter set on ohms scale. TS handel in neutral.
Red lead on white wire from brake switch and black lead on dark green then yellow. Zero ohms reading on both, then check the cutout on the brake lights by moving the TS lever up on the right check and down on the left check and the meter should read infinity. Brake wiring in TS is good.
Right turn- Red lead on purple, black lead on dark green, switch lever in up.
Zero ohms.
Left turn- Red lead on purple, black lead on Yellow, switch lever down.
Zero ohms.
Exactly Right. VV
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 10-07-2014, 08:47 AM   #6
Pzary3233
Thank you guys for the help I'm not armed with a bit more information to get this worked out. still waiting on the turn signal switch, it's currently back ordered...
VetteVet - I am actually working on a 68 for this project, rather then a 60-66 truck.
I'll attack the truck again tonight with my multimeter and test light. I am not very good with wiring diagrams so again thanks for the help!
I'll test the turn signal switch as well as follow the orange wire and see where that gets me.
Old 10-07-2014, 12:03 PM   #7
_Ogre
_Ogre's Avatar
about time vettevet chimed in
so... get power to the orange wire, get the marker lights working and power in/out of the brake switch
personally i'd check wires and connectors before changing out the ts switch, you may just have corrosion in the column connector
i'm more of a 55-59 and aftermarket harness guy, but the basic circuits haven't changed much
i remember trying to understand the ts switch in the days before the internet, back when i had to drive my dinosaur to the library
Old 10-08-2014, 12:13 AM   #8
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Sorry I missed that, I just looked at the 63 in your signature and thought it was the year. I usually don't goof up like that but the good thing is, they are pretty much the same. Good luck on the trouble shooting. VV
VetteVet
Old 02-02-2015, 10:09 AM   #9
Pzary3233
All right, finally got this all figured out.
First I pulled the fuse box to make sure that everything was ok on the back side of the block.
Issue #1 - The orange wires coming from the block had a large amount of rust scale on the back of the box. Cleaned it all up and then the orange wire had power! Volia, had parking lights and a dome light! The orange power wire is the key to the lights!
Issue #2 - Turn Signal switch - I pulled the steering wheel off and the switch pretty much fell apart as I was pulling it out. I was afraid of doing that job but ended up rebuilding the column as well.
Now everything works as it should. One parking light had a ground issue but that has since been resolved.
Something that helped me out a lot was printing out the wiring diagram for the entire truck and laminating it. Then Highlighting the wires I was looking for - that was I can see where it goes and where I needed to troubleshoot.
Old 02-02-2015, 01:58 PM   #10
_Ogre
_Ogre's Avatar
thanks for the update and glad everything is working
Old 02-02-2015, 01:59 PM   #11
Pzary3233
Yeah, I hate it when threads get left without the issue resolved.
I couldn't have done the electrical with you you and VetVette's help!
Old 05-11-2020, 05:18 PM   #12
randy500
Ttt for Nathan Rosser
randy500 is offline   Reply With Quote
