05-05-2020, 11:54 PM | #1 |
Active Member
Ammeter or not?
Hi Folks, I have a 71 K20 pickup that I have almost finished wiring up with a painless system. I replaced the 60 amp alternator with a one wire internally regulated 150 amp alternator. Should I leave the ammeter hooked up or am I in danger of burning it up. Anybody know what it is rated for? Thanks, Jack
05-06-2020, 08:13 AM | #2 |
Re: Ammeter or not?
I would not run it. Just do a volt gauge conversion or run a separate volt meter.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
05-06-2020, 10:49 AM | #3 | |
Msgt USAF Ret
Re: Ammeter or not?
Depending on how the painless wiring circuit is designed the ammeter may or may not work. It may even be set up for a voltmeter. If you look at the page your posting on you will see a thread about two rows down that will give you tons of information on the ammeter. If yours is not wired like the original harness it will not work, but I think it is covered in that thread and if you need any help on wiring it right we will bee happy to do that.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
05-06-2020, 01:07 PM | #4 | |
Active Member
Well thank you sir, I will take a look at that thread. I appreciate the help guys. Cheers Posted via Mobile Device |
