05-19-2020, 05:21 PM | #1 |
Cam shaft question
Hello. Would like to know if there any one with experience can help me with that.
Looking to buy a camshaft that give me aggrassive sound & engine shaking for cars show purposes . Engine is 350 SBC Thanks
guys,,,im overseas member..so please ,,respond me with easy english,coz its my second language....thanks --c30 1966 frame off 5 years restoration ; Finished; Chevy suburban 1958 restoration ( In progress ) 85 c10 "back to original project <Finished> " 81 c10 "back to original ( later) " 85 c10 cattleman edition lifted ( finished)> K1500 1989 full restoration ( soon ) S10 1991 in progress |
05-19-2020, 05:37 PM | #2 |
Re: Cam shaft question
05-20-2020, 12:42 AM | #3 | ||
"I ain't nobody, dork."
That'll do it. Ground for sound...
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
05-20-2020, 12:23 PM | #4 |
Keep the fine print in mind..."Needs 9:1 Compression, 2500+ Stall, Intake, Gears & Headers" ... and don't expect your 350 perform well without all that. It'll probably sound good though! -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
05-20-2020, 07:18 PM | #5 | ||
I have a friend that uses one of those cams and has to run 24 degrees of initial advance to get it to even run right. Why he hasn't yarded that thing out of his 350 is beyond me.
Gary
05-20-2020, 08:39 PM | #6 |
The Muthathumpr is the most extreme one , but they make a less radical one called the Thumpr. Other than that, I don't know anything more about it though.
05-20-2020, 09:36 PM | #7 |
60-66 Nut
If you want a lopey sound, I would go with a cam with 230*+ @.050 and a 108 LSA.
05-20-2020, 11:51 PM | #8 |
Flowmasters. They can make anything sound good, plus headers.
Also advancing the timing induces more "thump". Although they won't work as well as a cam. They can get you by or amplify a cam change. |
05-21-2020, 05:11 PM | #9 |
Check out a Crane 274h06 grind. Elgin, Summit, and others also offer a version of it. 218@.050 duration but ground on a 106 lobe separation. Works well with lower compression ( 8.75-9.5 ), but still has a rough idle. Works well in a stock to mildly modified small block.
Chris 1966 Chevy C10 LWB, 434 sbc, TH350, 12-bolt, factory suspension, pump gas 7.02 @ 95.8, 1.45 60' 1965 Chevy C10 LWB, 355 sbc, TH350, daily driver |
05-21-2020, 05:17 PM | #10 |
Wow 106 LSA, will that even idle less than a grand?
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
05-21-2020, 10:37 PM | #11 |
Thanks guy. Lets see more experience from the others. Videos are very welcome to post here
