05-29-2020, 06:03 PM | #1 |
400 turbo, no park, why?
I have a 1970 one ton truck with a 350 engine and a 400 turbo, I think it was originally a big camper truck, but has been made into a flatbed, the transmission has no park from the factory. Why did they do this?
05-29-2020, 08:08 PM | #2 | |
Moderator
Re: 400 turbo, no park, why?
They all have a Park position...above Reverse....PRND2L Does the trans have a large hand brake drum on the output shaft?
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox |
05-29-2020, 10:58 PM | #3 |
My 69 GMC was like that. No parking pawl in the trans and just RNDL on the column. I changed out the column to a tilt and put the lever in the trans when I rebuilt it. I think the reason was the GVW rating. Somewhere along the line I think they thought a 10k plus rated truck would break the trans because a lot of people do not set the parking brake. Without park it was mandatory that you did. I've seen quite a few that way in both the 10 and 14k ratings.
05-30-2020, 07:34 PM | #4 |
Moderator
Thanks KW....
That's why I asked OP about large handbrake drum on rear of trans... 10k and 14k trucks are strange like that... OP listed his truck as a 1970 One Ton truck.... Hence my response
05-31-2020, 12:21 AM | #5 |
Mine did not have the P brake on the trans, just the normal drums on the rear axle. When I got my 69 it was a class B motor home that was all rotted out with only 49k on the speedo
06-01-2020, 12:00 PM | #6 |
Yes, my truck is just like KWMECH's. I guess you could call it a motor home, but it is a truck cab with a humongous camper on back that was removed by PO to make a flatbed. He told me about the park and I would have thought he was full of it, but the column indicator doesn't have P either. Hence, I asked my question.
06-01-2020, 02:30 PM | #7 |
Yeah, mine used to be a Class B motorhome that was rotted beyond repair. I cut 2 feet of frame off the back and still ended up with a 10' long deck
