Old 09-16-2019, 11:10 PM   #1
19Loki67
PBFab frame stiffener
Has anyone used the PBFab frame stiffener with a RideTech strongarm rear coilover setup?
19Loki67 is offline   Reply With Quote
Old 09-19-2019, 09:08 PM   #2
19Loki67
Re: PBFab frame stiffener
Bump
Old 09-26-2019, 01:42 AM   #3
EVRLET
EVRLET's Avatar
I don’t have the frame stiffner but I do have the rest of the PB front and rear suspension. What are your concerns or questions?
Customization is what you want it to look like -- not what other people think it should look like
EVRLET is offline   Reply With Quote
Old 09-26-2019, 11:20 AM   #4
19Loki67
I’m wondering if the ride tech trailing arms will mount to the trailing arm mounts on the frame stiffener. Like is the spread on the mounts the same?
Old 09-26-2019, 07:15 PM   #5
SCOTI
SCOTI's Avatar
They should be. The manufacturers are who I would reach out to though to be certain.
That being said, if one or the other required custom rear-end mounts to compensate for some sort of design change, then I would be hesitant. If both set-ups work w/a factory T/A rear end, I would think you'll be ok.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
