09-20-2013, 12:28 PM | #1 |
Old member
Time to ask?'s
I need to know what motor mounts I can use with the LSX mounts I have?
First picture. Can anyone post pictures are links to a stock LSX 6.0 thread on how the installed it? Will I have to cut the frame rail to make the AC work? Also have the 700 r4 transmission now will the 4l80e trans sit in the same spot? Thanks guy's.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
09-20-2013, 12:30 PM | #2 |
Re: Time to ask?'s
stock mounts will work.
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
09-20-2013, 12:39 PM | #3 |
Old member
Re: Time to ask?'s
So the stock 71 chevy mounts will work with this set of mounts... Cool! Thanks mooseknuckles.
09-20-2013, 01:56 PM | #4 | |
meowMEOWmeowMEOW
Re: Time to ask?'s
Seriously tho, I did an install with the same combo (sans the '71, but I'm using the 71 front running gear, so it can't be that different). Regular ol' sbc motor mounts will fit to the plates and your truck. I re-used some I had sitting around, but with how hard they end up being to access once installed, I'd get a good set of poly's if I were to do it again. The 350/700r4 combo sat different than my current setup. I moved the engine forward a tad, and even so, the length of the 4l80e required me to slide the crossmember back a touch to fit. The 700 and the 80e also use different mount styles, so you'll need to re-drill the crossmember and mount the new-style trans mount.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
09-20-2013, 07:00 PM | #5 |
Old member
Re: Time to ask?'s
Thanks I can handle that but just wanted to know up front. Thanks.
09-23-2013, 11:26 AM | #6 |
Re: Time to ask?'s
The passenger side adapter plate won't clear the truck A/C compressor. If you are using an automotive accessory setup, it's a non-issue. With truck accessory mounts, the compressor itself will drop into the pocket created by the bent part of the stock frame rail, but running the lines may be a challenge.
Matt Cramer 1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD 4.8 LS build thread |
09-23-2013, 01:27 PM | #7 | |
Boosted Member
Re: Time to ask?'s
Still had to take the plasma to the frame rail to clear the lines.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
09-23-2013, 04:13 PM | #8 |
Old member
Re: Time to ask?'s
Thanks, I'm going to move it up on top with a kit and get new pulley put on mine.
