05-14-2017, 10:16 PM | #1 |
backfire through carb, need help
I am almost embarrassed to ask this, but i really am at my whits end here. Here is what i have, new 383 stroker motor, full roller, Edlebrock aluminium heads, new msd distributor, msd 6al box, Fitech fuel injection, initial timing set at 12 degrees and total at 34 degrees. motor starts right up and idles great, slow roll into throttle, it runs great, stab the throttle, and poof up through the carb, sometimes even killing the motor. i have adjusted the valves several times, check timing several times and still this issue exists.
Any help here would be great. |
05-14-2017, 11:06 PM | #2 |
Re: backfire through carb, need help
Try more timing!
Bump it up to 16 initial. Or have you tried increasing your accelerator pump setting? Last edited by geezer#99; 05-14-2017 at 11:19 PM. |
05-14-2017, 11:23 PM | #3 |
05-15-2017, 06:59 AM | #4 |
Have sufficient fuel pressure for the injection?
05-15-2017, 08:06 AM | #5 |
05-15-2017, 08:12 AM | #6 |
Typically lean surge is evidenced by a backfire out the carb while rich is out the exhaust.
On a higher mileage motor can be signs of a valve or seat issue. Or a valve misadjustment. A/F go lean on throttle transition?
05-15-2017, 08:26 AM | #7 | |
Posted via Mobile Device |
05-15-2017, 08:29 AM | #8 | |
05-28-2017, 12:37 AM | #9 |
Update:
really frustrated here, here is the full background: Started with new 350, mild flat tappet cam, Edelbrock RPM aluminium heads, RPM intake, complete new MSD Ignition - 2 wire Distributor, 6AL box, a blaster coil and Fitech Fuel Injection. With this set up, i was having backfire issue when you quickly hit the gas. At idle, it is great, or slowly hit the gas it is ok, but jam the throttle from an idel, boom. With this said, i decided after this that i wanted a good reason to get my ultimate motor, a 383 full roller stroker, so i build a 383 stroker, a Howards full roller mild cam, along with the above mentioned Aluminium heads, intake and MSD ignition and Fitech. With this setup i again had the backfire issue when i quickly hit the gas. At idle, it is great, slowly getting on the throttle it seems to be fine, but jam the throttle from an idle, boom up through the carb. So out of alot of frustration, i adjusted the timing, from 10 - 16 btdc, i removed the Fitech and set a carb i know is good on it and same issue. i have checked and re-checked the spark plug wires, and i am now going to try to remove the MSD and try to install my old HEI and see what happens. Im just so frustrated at this point. Any and all ideas are appreciated!!!! |
05-28-2017, 12:38 AM | #10 |
vacuum at idle is 12 to 13", steady, slowly get into the gas and it dips and then jumps just as it should.
05-28-2017, 12:45 AM | #11 |
howards roller cam:
intake duration at .50 lift = 219 Exhaust duration at .50 lift = 225 intake lift = 510 exhaust lift = 525 lob separation = 110 hydraulic lifter roller cam good from 1500 - 5600 rpm |
05-28-2017, 06:25 AM | #12 |
laying low
I think I would measure the voltage to the distributor.
You may or may not know HEI needs a solid 12 volts to run best. If you used the original distributor power wire on the truck it won't do. It is a resistor wire dropping the volts down to 8 or 9 or so for the old points type ignition. If supply voltage is good I'd switch back to the HEI distributor and give it a try. Just because the MSD unit was new doesn't mean it can't be bad.
05-28-2017, 12:24 PM | #13 | |
So, now I'm too the ignition. I disconnected the entire MSD, wires and all and now going to try that. I also have another set of good wires I'll try also. Posted via Mobile Device Last edited by 88Stanger; 05-30-2017 at 10:13 AM. |
05-30-2017, 10:12 AM | #14 |
So I am at that point where frustration takes over, so I stopped, took a minute to think and here is what I am doing.
I took off the Fitech and all of the MSD ignition components. I then did a compression check, here are the numbers: 1 - 180#s 3 - 195#s 5 - 192#s 7 - 190#s 2 - 180#s 4 - 190#s 6 - 192#s 8 - 180#s The motor has about 30 min. on it. So these numbers may get a bit closer to each other, but otherwise they look good to me. I was able to get an brand new MSD single wire HEI Distributor for cheap so I have that to install and an old Edelbrock 650 that I know is good. I will install these and try to develop a base line, get it running good then slowly replace/introduce the MSD 6AL box, and then the Fitech. |
