09-28-2019, 07:39 PM | #26 |
Re: 1972 Blazer Steering
Has anyone used spacers on the back to align the tires? If so, do you know if that helps the wander at all?
09-29-2019, 03:35 PM | #27 |
10-12-2019, 08:55 PM | #28 |
Just tagging along here... I have a 72 Jimmy, 4x4, 4" new lift, new red head box, alignment complete and after a very frustrating 1.5 years I'm still chasing the front end all over on anything other than a straight road. The only thing that's not new is the steering column.... so I just ordered one. I have sway bars still sitting pretty in their boxes but no idea how to fab them up to work
72' JIMMY 454 |
10-14-2019, 07:36 PM | #29 |
Moving this to where I should have posted to start with:I asked about my front driver's side wheel sticking out 1" further than the passenger side.
This from Hemi43: Measure the distance from the inside of the front tire to the side of the frame. If the measurements are the same, then this will rule out the axle being shifted to one side. I would then look at the front sheet metal being off location. (rotted/broken body mounts or rad support.)
72' JIMMY 454 |
10-14-2019, 07:51 PM | #30 |
I think we'd like to see several pics of your axle, spring perches, axle tubes, and steering linkages to start. Pics of your tire stickout as well general fender/panel fitment may help as well. Plus those measurements asked for above.
10-14-2019, 07:54 PM | #31 |
Here's some pics I just took tonight to see if anyone notices anything wrong that would make my steering "dart back and forth" as others described above. I'll do the measurement as Hemi43 suggested tomorrow
72' JIMMY 454 |
10-14-2019, 08:07 PM | #32 |
Yes Sir, I'll wear ya'll out with photos tomorrow after work. It's darker than dirt here now
72' JIMMY 454 |
10-15-2019, 09:41 AM | #33 |
I can't see any issues in the pictures. I know you said you had the front aligned already, but i would measure the toe-in to see where it's at. If the alignment shop used factory specs, you won't have enough toe-in. With your large tires I would aim for 3/16". I'm sure everyone is tired of me saying this, but increase your caster with angled shim blocks. The more caster you have, the better your truck will go down the road. (within reason) I have 6 1/2 degrees.
Edit; I just re-read your post and see you have a redhead box. If this is a fast ratio, that may cause some problems, IMO. |
10-15-2019, 12:27 PM | #34 |
Thank you and I'm never tired of hearing a potential solution! I will certainly set it to your recommended specs. The Jimmy steered the same when I bought it, so I thought installing the new gear box would fix it. Unfortunately it did nothing good or bad.
Two different body shops with frame machines said the frame is good with no signs of damage or altercation. All the spring perches are original and measure correctly. All that to say, you have to be right.
72' JIMMY 454 |
10-15-2019, 02:28 PM | #35 |
Can we see pics of the spring perches and the tire stick out you mentioned?
Assuming all this is good - I'm inclined to agree that it's your toe in setting and possibly caster as mentioned. |
10-15-2019, 06:05 PM | #36 |
Trying to get the pics to load...
72' JIMMY 454 |
10-15-2019, 06:07 PM | #37 |
This was the best way I could show how the driver's wheel sticks out approximately an inch further than the passenger side.
72' JIMMY 454 |
10-15-2019, 06:10 PM | #38 |
grasping at straws here, but do you have a quick ratio steering box and are the u bolt nuts on the steering dampner tight, the pic looks like there is wear on both sides, couldn't blow up the pic large enuff to tell
does that bolt look like its going into the center of the leaf spring in the fifth pic
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 10-15-2019 at 06:20 PM. |
10-15-2019, 07:22 PM | #39 |
Here's the Redhead gear(steering) box info for what I put in:
2851: 1968 – 1976 PICKUPS, SUBURBANS, BLAZERS 4X4 Rated 5.00 out of 5 based on 1 customer rating(1 customer review) From $266.00 PART #2851. Fits most 1968 – 1976 Chevy and GMC Pickups, Suburban’s and Blazers 4WD. This steering gear has a large input shaft, large piston, NOTCHED SECTOR SHAFT (clamp style pitman arm), flair fittings and is the pickup style mount. If you have a sector (output) shaft that the pitman arm is held on with a nut and washer then you the 2WD steering gear, our part number 2850. You can either order this steering gear and change your pitman arm or you can order the 2850. This gear comes stock as the 15:1 ratio (3 to 3.5 turns lock to lock). If you would the 18:1 ratio (4 – 4.5 turns lock to lock) please order 2851 4T. On another note: I measured from the inner tire to the frame as per Hemi43's suggestion and the driver's side is 1/2" further to the outside than the passenger. Looks like 2", so maybe the front driver's side finder is causing the illusion. ...and Yes Sir, the bolt is somehow bent at the end. No telling how those morons did that?
72' JIMMY 454 Last edited by BIG BLOCK JIMMY; 10-15-2019 at 07:28 PM. |
10-15-2019, 07:38 PM | #40 |
Can we see the axle tubes and the spring perches on the axle.
Also its still a 6 lug truck, right? |
10-15-2019, 08:20 PM | #41 |
Yes it's a 6 lug
72' JIMMY 454 |
10-15-2019, 08:22 PM | #42 |
Last one
72' JIMMY 454 |
10-15-2019, 09:01 PM | #43 |
Can you get one where we can see the linkage and the pitman arm? Like from the front of the truck looking back.
-Bruce 1971 K5 Blazer 4WD |
10-16-2019, 08:16 AM | #44 |
It looks like you've covered every possibility and.....
maybe you have...but did you check to see if the axle tube on the passenger side is bent? At some point in it's life....it may have taken a hit...?
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. Last edited by A1971Blazer; 10-16-2019 at 08:28 AM. |
10-16-2019, 09:42 AM | #45 |
Do you have a second person to turn the steering wheel while you look underneath for any movement
Are all four wheels and tires the same? But, my eclipse hated different tires on the back axle
10-16-2019, 02:40 PM | #46 |
I'd also try to measure rim width. That tire stick out is weird...
Did you install the rims/tires or buy it with those on there? |
10-16-2019, 03:29 PM | #47 |
Tires/wheels came with the truck. Tires are the same and the wheels appear to be the same, but if I have to I will have them removed to measure.
I'll have my wife turn the steering wheel while under it again, in case I missed something before. I did check the steering stabilizer tightness and it was good. I thought about taking it off, just for the "why not" sake of trying something. I'm going to get the toe-in and caster adjusted as suggested as quickly as possible and will rotate the tires just in case a tire is bad (highly unlikely).
72' JIMMY 454 |
10-16-2019, 03:52 PM | #48 |
Measure your spindle and everything when you have it apart. The tires should be the same on both sides and that variance is odd. You can take a measurement from the knuckle to the mounting point for the rim and see if it is longer than the other side. It could also be the backspacing on the rim. If it’s the rim replace them. Measure your knuckle distance from where it mounts on the tube and the ball joints mount. I doubt it’s that but who knows. I’ve seen worse.
Kirk 72 Blazer CST 4wd highlander 66 Nova |
10-16-2019, 03:58 PM | #49 |
I just checked my kick out on the tires using the straight edge and they are nearly identical on both sides. Definitely figure out what’s up with that variance. I bet that’s your problem.
10-16-2019, 05:06 PM | #50 |
Is this the correct ratio for the steering box?: 15:1 ratio (3 to 3.5 turns lock to lock)
Will do Blazerowner, thanks
72' JIMMY 454 Last edited by BIG BLOCK JIMMY; 10-16-2019 at 05:13 PM. |
