Old 10-21-2020, 03:40 AM   #1
BigRandy
BigRandy's Avatar
1974-454 What "Mark" do I have?
Wikipedia lists BBC stats and GM product designations for passenger cars but I can't find a product code for those used in half ton trucks, specifically the 454 used in the C10 from 1974.
I know it's a low HP engine but what do I look for when researching bolt ons like better heads, cam, intake?
I'm entertaining the idea of a small cam but IIRC any increased lift while running peanut heads may be a problem.
In short: What bolt ons can I add to wake it up?
Repairing and driving old trucks is an analog experience. No computers or sensors and they can be fixed with basic hand tools
BigRandy is offline   Reply With Quote
Old 10-21-2020, 04:13 AM   #2
franken
Re: 1974-454 What "Mark" do I have?
The Mark IV is what we think of as the big block after the W-head engines ~65/66 and up to about 90.
franken is online now   Reply With Quote
Old 10-21-2020, 07:48 AM   #3
b454rat
If it's from a 74 good chances it has 049 or 781s, those are best heads you could get for a street motor, AKA junkyard heads. I had each, last one was over 400 horse easy. I wouldn't worry too much bout putting in a bigger cam with whatever head, use matching springs and run it.
Old 10-21-2020, 11:04 AM   #4
kwmech
Waking up a 74 big block is easy. Bump the compression to no more than 9-1 and put in a mild cam. stock heads are fine unless you plan on reving it more than 5k. Doing those 2 things will almost double the HP from the factory
Old 10-21-2020, 01:12 PM   #5
The Rocknrod
Moderator
The Rocknrod's Avatar
Originally Posted by BigRandy View Post
Wikipedia lists BBC stats and GM product designations for passenger cars but I can't find a product code for those used in half ton trucks, specifically the 454 used in the C10 from 1974. ...
This article says it was used in 74 on commercial trucks - https://itstillruns.com/1974-gm-big-...s-7630732.html
The block should have a stamped number on the front of the passenger side head, might tell you more.
Hagerty shows a 454 in a 2 door stepside longbed for that year though so who knows?
You could go to the GM Heritage Center and download the 1974 Chevrolet Trucks booklet to find out - https://www.gmheritagecenter.com/gm-...tion-kits.html
It shows on page 23 of that PDF document that the C10 had a 454 option code #LF8. With a whopping 230HP advertised.
Old 10-22-2020, 02:54 AM   #6
BigRandy
BigRandy's Avatar
Thanks to everyone for the info. It's exactly what I was after.
B454RAT: If I read correctly you were using peanut heads when you got 400HP. What all did you do to get that number?
Old 10-22-2020, 11:28 AM   #7
b454rat
10:1, ran 93, 781 heads, comp came extreme energy 268, dual plane intake Holley 3310 750, used manifolds cause trying to fit headers n a G body with 4-speed was tough. Never got the motor 100% dialed in but ran like a mother f’r. Regret selling it.....
Old 10-22-2020, 12:42 PM   #8
Tom
driving is in my blood
Tom's Avatar
No, he had oval port heads like any 454 from 1974 should have including yours. Peanut ports were 80's.
Old 10-22-2020, 01:02 PM   #9
b454rat
Other than tall deck was even any peanut ports used? Most of what Ive seen were 049 n 781s.
Old 10-23-2020, 03:06 AM   #10
BigRandy
BigRandy's Avatar
Craaaap! I didn't know that. I was sure I'd read somewhere the low HP 454's had peanut ports. I feel better about it now.
I see some some upgrades in my future.
Old 10-23-2020, 08:22 AM   #11
Warrens69GMC
Warrens69GMC's Avatar
Started in 1975
346236.....75-87...oval...OPEN...454, 120cc chamber, 225/116cc ports.
So if that was a late 1974, it could have peanut ports, which IMO isn't a bad thing
Old 10-23-2020, 09:56 AM   #12
geezer#99
geezer#99's Avatar
Only reference to peanut ports I’ve found is a 1986 casting.
Post your head casting numbers.
That’ll clear it up.
geezer#99 is online now   Reply With Quote
