Old 02-19-2019, 12:01 AM   #1
Free Candy Inside
My original gas tank modification
As many of you have done I ripped out the original gas tank behind the seat on my 66 C50. I couldn’t see just throwing it out so I decided to cut it up and have it double as a storage compartment for stuff behind my seat. I also made some corner 6x9 speaker mounts. Last pic is after I sprayed the interior with a tintable bed liner I tinted to match the factory fawn color. Anyways, hope you like my gas tank mod.
63 1ton Paneltruck build: http://67-72chevytrucks.com/vboard/s...d.php?t=627721
Instagram: jaked937
Free Candy Inside is offline   Reply With Quote
Old 02-19-2019, 12:02 AM   #2
Free Candy Inside
Re: My original gas tank modification
Another view
Instagram: jaked937
Old 02-19-2019, 12:03 AM   #3
Free Candy Inside
And finally bolted in after spraying the bed liner in the cab. I also decided to run my speaker wires up through the hole of the original fuel line hole.
Instagram: jaked937
Old 02-19-2019, 12:58 AM   #4
'63GENIII
'63GENIII's Avatar
That is one of the most creative ideas for an unused tank ever. Ive had mine on the side yard for over a year while I struggle to store stuff in the truck. Most anything I keep behind the seat usually ends up at my feet rolling around.
Brilliant idea!
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 02-19-2019, 01:15 AM   #5
cwcarpenter98
cwcarpenter98's Avatar
Man, I love this idea! If I ever swap to a different tank, I will probably do something similar
Christian Carpenter
1963 C10 - Frankentruck 283, 3 speed with overdrive
Overdrive wiring here
1981 C10 - Penny 305, th350
1995 Dodge Dakota Sport
Old 02-19-2019, 04:44 AM   #6
The Rocknrod
Moderator
The Rocknrod's Avatar
Sweet. Very creative.
Old 02-20-2019, 12:38 AM   #7
Captainfab
60-66 Nut
I agree......I imagine that a recently used tank would have to be washed out and aired out for a while before being used like that not to mention the possibility of an explosion when cutting it.
Old 02-20-2019, 12:49 AM   #8
'63GENIII
'63GENIII's Avatar
Kind of wondering about this myself as well. Mine's been dry a while and doesn't smell but I'd guess that a good soap and water "tank enema" may be prudent before hand.
I really dig this idea for storage though. Ive been racking my brain since I pulled the tank out only to have the solution sitting in the side yard the whole time.
Chris
'63 k15 long step
Old 02-20-2019, 06:51 AM   #9
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
" tank enema " God that made me laugh this morning. Thanks for that!! " tank enema " too funny.
Old 02-20-2019, 08:05 AM   #10
The Rocknrod
Moderator
Ya we forget the safety factor 'sometimes' when working at home. Something we would never do at work. Hopefully.
These guys power-washed a gas tank out for about 30 minutes, they said there was barely any smell of gas but. At about the 20 second mark:
https://youtu.be/XdXMRkQsDE8
Old 02-20-2019, 10:21 AM   #11
1998c1500
1998c1500's Avatar
I heard that you should fill the tank with water and then cut. Sounds messy but should displace the fumes inside the tank.
1965 C10
1967 Camaro
1998 C1500
2011 Colorado W/T
1998c1500 is offline   Reply With Quote
Old 02-20-2019, 10:43 AM   #12
The Rocknrod
Moderator
Using a pneumatic tool only, that would work.
Old 02-20-2019, 03:45 PM   #13
straight6chevyguy
straight6chevyguy's Avatar
Fill the tank with water.
sixtyfiveford on youtube welded a tank that way.
https://www.youtube.com/watch?v=G3qToCjW-hc
1965 chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601
1976 chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037
1998 chevy c1500 4.3L 5speed (My current driver)
2002 Chevy s10 4.3L auto 4x4
1971 mercury monterey wagon 400 auto
To many projects!
straight6chevyguy is offline   Reply With Quote
Old 02-23-2019, 03:53 PM   #14
Free Candy Inside
This tank had been sitting in my shop for a few months empty. I took the sending unit out and the fill side was open. I then took it outside in the snow and threw a match in it just for the fun of it. Nothing happened so I started cutting away! Lol
Instagram: jaked937
