Old 12-11-2018, 12:14 PM   #1
Desert1957
Desert1957's Avatar
2004 Headlamp and Door handle upgrades
Just thought I would post these upgrades to my 04 Z71. If you want a cleaner look on the front end and doors.
[ATTACH][ATTACH]Name:  20181211_100548.jpg
Size:  29.0 KB[/ATTACH][/ATTACH]
Desert
Desert1957 is offline   Reply With Quote
Old 12-11-2018, 12:32 PM   #2
hatzie
Moderator
hatzie's Avatar
Re: 2004 Headlamp and Door handle upgrades
How was the fit on the aftermarket headlamps?
Can they be aimed properly?
If they fit well what is the brand?
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 12-11-2018, 12:36 PM   #3
Desert1957
Desert1957's Avatar
Aiming was no problem, fit and finish was above average, only issue the two lower tabs on the headlight buckets was a little loose in the rad support mount. I used some foam tape, problem solved.
Check Ebay for the Headlight/Turn signal kit , Door handles are a GM escalade part.
Desert
Old 12-11-2018, 12:40 PM   #4
Desert1957
Desert1957's Avatar
https://www.ebay.com/itm/CHROME-2003...0AAOSw-uhaYRWu
Made in China, same as everything.
Desert
Old 12-11-2018, 02:48 PM   #5
hatzie
Moderator
hatzie's Avatar
The new GM stuff is made in China too but the GM parts fit as they should.
The China lamp assemblies I tried out didn't adjust properly and one of the four didn't fit under the hood.
After the second no-fit set I decided to bite the bullet and pay for surplus market GM parts.
Glad you found some that worked for you.
Old 12-12-2018, 11:43 PM   #6
davischevy
davischevy's Avatar
I bought the ebay units, and they worked great.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 12-14-2018, 09:17 AM   #7
95 S_Trucker
95 S_Trucker's Avatar
FYI, your headlights and turn signal lenses are not DOT approved, and they will fail PA state inspection.
The reflectors built in to them need to be amber.
95 S_Trucker is offline   Reply With Quote
Old 12-14-2018, 12:32 PM   #8
hatzie
Moderator
hatzie's Avatar
They look ilke the light output is probably fine but they are obviously non-compliant. Not sure whether it'll become an imperial entanglement in PA before the annual safety inspection. PA is the bleeding edge of the Nanny Northeast... Depends on what Johnny Law is looking at when you drive by him.
It's not just in the Northeastern Nanny States, where we have compulsory safety inspections, that people need to worry about this now.
I've seen regular vehicles pulled over by DOT cops in the middle of nowhere out West. Likely either illegal tint, exhaust noise, or non-compliant headlamps/taillamps.
Old 12-15-2018, 09:26 AM   #9
Desert1957
Desert1957's Avatar
I have a "Connection" so no problems.
Desert
Old 12-25-2018, 02:33 AM   #10
stroker87
i have some aftermarket in my truck fit fine look good but the light is aimed to the right a lot no adjustment to get it pointed straight, do these point the light to the right to?
stroker87 is offline   Reply With Quote
Old 12-26-2018, 09:27 AM   #11
Desert1957
Desert1957's Avatar
Not as much as I would like, but I've had no complaints from oncoming drivers.
Desert
Old 12-26-2018, 11:05 AM   #12
hatzie
Moderator
hatzie's Avatar
RH=Passenger side of North American market vehicles.
The aim point skewing toward the RH side of the truck causes issues with your own ability to see directly ahead. If they are skewed to the RH side you won't get problems with on-coming traffic. Oncoming traffic will only notice beams skewed unreasonably to the LH side of your vehicle.
The aimpoint being too far Left is a defect I found on the two sets of Chinese lamps I tried in my truck.
The Left-Right Horizontal optical centre and actual Vertical centreline of US-DOT compliant lamp housings will be indicated by a mark. On both of my 2003-2006 Silverado GM housings it looks like the Greek letter Theta θ.
When you aim the lamps for US-DOT compliance;
The centre of the low beam high-intensity spot of both lamps on the aiming target should be a 6° downtilt from the lamp centreline... This works out, at 25', to approximately 1" below the horizontal line drawn on your target at the actual centre height of the headlamps. This is not the edges it's the centre of the hotspot.
The centre of the high intensity spot should be approximately 1" to the Left of the vertical aim line drawn down toward the ground at the lamp optical centre point. Again this is not the edges it's the centre of the hotspot.
Old 12-27-2018, 02:30 PM   #13
Desert1957
Desert1957's Avatar
I haven't gone through this aiming procedure, But with the bulb upgrade to Silverstar ZXE the pattern seems a little to centered out of the box. Even and overlapping, nothing weird.
I will try this aiming procedure and let you know how it turns out.
Desert
Old 12-27-2018, 02:51 PM   #14
hatzie
Moderator
hatzie's Avatar
There are no Horizontal aiming screws on the 03-07 Silverado. Only Vertical up and down aimpoint can be adjusted.
If the lamps hotspots are skewed horizontally left or right when you check them that's where they will stay.
If someone knows of a blocking plug that can be drilled out to access a horizontal aiming screw on the 03-07 Silverado headlamps please step up and tell all.
