Old 02-23-2021, 12:12 PM   #1
blazer2007
HEI rebuild ? on lube for main shaft
Just freshened up my hei. as it was gummed up but when installing the main shaft into the housing are you supposed to put anything on the shaft.
blazer2007 is offline   Reply With Quote
Old 02-23-2021, 04:57 PM   #2
Wrenchbender Ret
Re: HEI rebuild ? on lube for main shaft
Yes. put a small amount of grease like disc brake wheel brg. grease on the shaft. Also put a pinch on the pivot pins that the flyweights go on. Put a little on the bottom of the weights too. Be sure & put a heat transfer grease on the bottom of the module.
George
Wrenchbender Ret is offline   Reply With Quote
Old 02-24-2021, 11:41 AM   #3
blazer2007
thanks, found all the info but couldn,t find anything on shaft lube except the top seal lube under the pickup. I did learn to use the right paste for the module NOT DIE ELECTRIC GREASE
