Old 08-26-2019, 06:25 PM   #676
chewychevy67
Re: 67 GMC super custom build
I believe 283 was red like the inline 6's were ( at least in Canada) and 327 was orange. I had a 67 gmc with a 283 and it was red. This is the original 327 from another 67 I have and it is orange. It looks pretty original.
chewychevy67 is offline   Reply With Quote
Old 09-25-2019, 12:53 PM   #677
chewychevy67
Fog lights are in the bumper. They are fully adjustable up-Down and left-right. Might have to make a slight modification to the outer bumper brackets.
Old 09-25-2019, 01:01 PM   #678
Kronald_70GMC
Kronald_70GMC's Avatar
Now that is cool! Good stuff
Kyle
1970 GMC "Project Splice"
2017 Silverado LTZ (Daily Driver)
IG: kyle_ronald
Kronald_70GMC is offline   Reply With Quote
Old 09-25-2019, 02:15 PM   #679
IronCanine
I'm trying....
IronCanine's Avatar
That is super slick.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076
1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352
1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290
1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555
"Sometimes I wonder if zander208 was even real..."
IronCanine is offline   Reply With Quote
Old 09-29-2019, 08:12 AM   #680
Last_Paladin
If I may, what are the light buckets from?
Last_Paladin is offline   Reply With Quote
Old 09-29-2019, 08:20 AM   #681
chewychevy67
They are from a 1957 Cadillac
Old 09-29-2019, 07:51 PM   #682
67 Burb
67 Burb's Avatar
Those look really good Rod, (and like factory). Bang-on with my mocked-up photo in post 652.
Bob
1967 2wd Burb, 350/TH350, 3.73 posi
67 Burb is offline   Reply With Quote
Old 10-11-2019, 05:38 PM   #683
chewychevy67
I put my headlight relays into a external regulator housing. I wanted better lighting but didn't want to pur modern relays into my engine bay. They would look out of place. Now I just need to change the lighting harness to work with this. I saw another member do this and thought it was clean looking.
Old 10-11-2019, 05:39 PM   #684
chewychevy67
Few more
Old 10-11-2019, 06:26 PM   #685
67 Burb
67 Burb's Avatar
Slick!
Bob
Old 10-16-2019, 11:40 AM   #686
chewychevy67
I got some led fog lights for my truck and made a relay for them as well. I had to add the ring to the base of the led lights as the originals mounted different than most bulbs of the era. I won't throw out the originals though. I also ordered led headlights that have a glass pattern like the originals and got robznob11's led bulbs for everywhere else. It can still look original with modern lighting! https://www.ebay.com/itm/5-3-4-Stock...53.m1438.l2649
Old 10-16-2019, 11:42 AM   #687
Kronald_70GMC
That's pretty damn cool man. Good stuff!
Kyle
IG: kyle_ronald
Old 10-17-2019, 10:58 AM   #688
clay68c10
clay68c10's Avatar
Nice lighting! Where did you get the headlights?
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 10-17-2019, 11:09 AM   #689
chewychevy67
I got the headlights from octane lighting. They fit the headlight buckets with no cutting which I liked as well.
Old 10-17-2019, 04:58 PM   #690
chewychevy67
Starting to get ready to fire it up and making sure all the brackets fit as they should. It's amazing how crude gm made the ac brackets in these years. Guess it was just for a work truck back then. I'm going to mount the instant aire vacuum port to the ac bracket on the top corner. It's close to where Pontiac put it on their engines.
Old 10-22-2019, 04:00 PM   #691
chewychevy67
I had to redo the oil pan as everyone says to put dabs of rtv in the corners to the block with it so I did. Hope this is the last time it's upside down and hope it doesn't leak. Now I can finish the top side!
Old 10-22-2019, 04:26 PM   #692
Kronald_70GMC
I had to redo the oil pan as everyone says to put dabs of rtv in the corners to the block with it so I did. Hope this is the last time it's upside down and hope it doesn't leak. Now I can fi ish the top side!
Looks pretty nice! So shiny
Kyle
IG: kyle_ronald
Old 10-22-2019, 05:22 PM   #693
chewychevy67
These are my goodies for this engine to make it period correct. I have doubles of most. Going to put the block heater in this afternoon. The one cord is original from my 67 and the other is Nos. The angle of the plug to the heater is different and the Nos is about a foot longer and has a ground on it.
Old 11-02-2019, 08:50 PM   #694
chewychevy67
Making sure all the brackets line up and so far so good. Not going to mount the ac compressor till its in the truck. Now to take the accessories off and get it in the frame and start it!
Old 11-02-2019, 09:17 PM   #695
IronCanine
I'm trying....
IronCanine's Avatar
So fresh and so clean.
Old 11-02-2019, 09:36 PM   #696
chewychevy67
I almost don't want to hide this detail with the cab and hood. You must be relaxing this weekend. I'm waiting for more of your assembly pictures.
Old 11-02-2019, 10:06 PM   #697
IronCanine
I'm trying....
IronCanine's Avatar
She's been winning some battles. Hopefully more progress in the coming days...loving what you're cooking though. Thanks for the pics!
Old 01-14-2020, 09:50 PM   #698
chewychevy67
So I have been fighting my distributor for. The last while. It won't sit down clean to the intake. It sits 1/8" or 0.010 high and bottoms out. Heads were shaved, block was not decked. All gm parts here and were checked by professionals before I assembled it. I've tried everything so I guess the pans gotta come back off and take a look at the oil pump-shaft connection. Thats all that's left. Good thing I haven't put oil in it yet. I have tried a few hei dizzy and they all sit exactly the same.
Old 01-14-2020, 10:46 PM   #699
72 tigger
72 tigger's Avatar
That’s frustrating, hope you can figure it out
71 C10
72 K20
72 K10 Super
Kirk
72 tigger is offline   Reply With Quote
Old 01-14-2020, 11:33 PM   #700
67 Burb
67 Burb's Avatar
How thick is the distributor gasket? I measured one and it seems to be about .054" thick.
Bob
