10-21-2018, 01:39 AM | #1 |
Crankshaft Serp Pulley Search
I am in need of a dual 6 groove serp belt crankshaft pulley for my small block. Does anyone know who makes one besides March? Any recommends?
Thanks |
10-21-2018, 08:35 PM | #2 |
Re: Crankshaft Serp Pulley Search
In '86 GM had a hybrid drive setup that used a ribbed belt and a v belt combination. I don't remember seeing a dual grove ribbed setup.
The whole point of a serpentine drive setup is just one belt drives all accessories, so I find this confusing.
10-21-2018, 11:08 PM | #3 |
60-66 Nut
Most people when they use more than one 6 ribbed belt on their accessory drive, still call it a serpentine belt even though it really is not.
10-21-2018, 11:16 PM | #4 |
60-66 Nut
The first that comes to mind is CVF Racing, who makes a ribbed belt accessory drive conversions, but theirs are designed for 8 ribbed belts and only for long water pumps.
https://www.cvfracing.com/chevy/smal...nversion-kits/
10-22-2018, 01:35 AM | #5 |
Thanks Captainfab, this is exactly what I am after. Instead of using two v-belts I want to use two ribbed/serpentine belts and not use any idlers and a tensioner. I have double humps heads which do not offer any mounting points and I am having a hard time finding what I want but this setup is what I am after. I can find the rest of the pulleys separately a little cheaper but I find sometimes spending a bit more is worth saving the headaches.
