05-06-2012, 06:31 PM | #1 |
Need Single peace drive shaft 80 c10 4 speed
As the title says i have an 80 c10 and it is currently a straight six with a two peace drive shaft with a farm truck 4 speed (low gear). i am planning on putting a 454 about 500hp and tq with a muncie m20 and i want to convert to a single peace drive shaft because i dont think the double can handle that much torque or am i wrong? The problem is that i cant seem to find any place that sells 80 c10 single peace drive shafts. So if anyone knows any places that sell them can you please post a link to there website or a phone number to get a hold of place that makes them. Thanks any help is good help !
05-06-2012, 06:50 PM | #2 |
Re: Need Single peace drive shaft 80 c10 4 speed
A 2-piece driveline is STRONGER than a long 1-piece. If this is a LWB truck you have no choice but to run a 2-piece with a Muncie 4 speed, A 1-piece would be too long.
05-06-2012, 07:47 PM | #3 |
it is a swb stepside and really i would of thought double makes more pressure points to break? i guess ill use the double then
05-06-2012, 11:43 PM | #4 |
I'd imagine if you take a measurement of the length, and go to a good junk yard you might be able to find something that fits your requirements. It doesn't necessarly have to be out of another '80 c10.
If your dead set on a 1 piece drive shaft, there is probably a drive shaft shop in your area that can make you one.
1963 Chevrolet C10 Stepside 1972 Pontiac GTO 1998 Dodge Viper GTS 1999 Jeep Cherokee XJ 2018 Chevy Camaro ZL1-1LE It's never too early to beef up my obituary |
05-07-2012, 03:18 PM | #5 |
do you guys happen to know if i could use the same double peace when i swap to a muncie m20 right now i got the saginaw farm truck 4 speed with one gear as low
05-07-2012, 11:49 PM | #6 |
Fabricate till you "puke"
Your swb truck should have a short enough shaft lenght, to handle a 1 pc unit.....wont happen on a lwb truck tho! To answer the ? you asked.....if you have a saginaw 3 or 4 spd trans (Id by a 7 bolt side cover...not top loader, with the long shift lever). The saginaw trans, is the same lenght, as an M-20/21 Muncie, & uses the same slip yolk. The next "fly in the ointment", will be engine placement( for /aft), when you go BB.... crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
